robot
sterob
robot
PostPosted: Fri Jun 24, 2011 8:55 am     Reply with quote
hi everyone, am a final year engineering student. please i need resources on robotics, a step-by-step approach. my project supervisor needs me to build a robot but i dont have any idea. please am in need of help, i need links,explanation,projects already done to help me start, anything useful. thanks
SherpaDoug
Try building Nbot
PostPosted: Fri Jun 24, 2011 9:04 am     Reply with quote
Google "nbot" to see info on a fun little 2 wheeled balancing robot. Especially if you are strong on programming, but weak on mechanical building, this mechanically simple robot could be a good project. I have wanted to build one for years but never had the time.
PostPosted: Fri Jun 24, 2011 9:51 am     Reply with quote
This site is for CCS C coding and not really a forum for robotics.
However, one of the largest robotics sites in the country can be found at:
http://www.seattlerobotics.org/
They even have a Getting Started section on their web page that should answer a lot of your questions.
sterob
PostPosted: Fri Jun 24, 2011 10:35 am     Reply with quote
thanks so much.
pls i stumbled a robot rover 'Wireless Dual Analog Joystick Controller with an Xbee Module' by KERON. PLS CAN ANYONE HELP ON THIS
PostPosted: Fri Jun 24, 2011 12:12 pm     Reply with quote
Help do what? The topic is pretty thorough, including all the code, what else
do you need?
We don't do robot builds on this site. I recommend going to a
robotics site for that kind of help (like the one I pointed youi to earlier).
After you get the robot built we can help with CCS programming/coding
issues...
BTW, if you are going to refer to a topic it is helpful to provide the link, like this:
http://www.ccsinfo.com/forum/viewtopic.php?t=44349
