EX_FAT.C not working
noyz
PostPosted: Sun Jun 12, 2011 9:38 am     Reply with quote
How is this possible pcwh comes with this example and it doesn't compile.
a lots of errors ..
but when i remove this line :
#device PASS_STRINGS = IN_RAM
only errors that remain are that attemting to make a pointer to a constant
ccs version 4.120
PostPosted: Sun Jun 12, 2011 4:21 pm     Reply with quote
It compiles with no problems in MPLAB.
CCS PCH C Compiler, Version 4.120, xxxxx       12-Jun-11 15:19
               Filename: C:\Program Files\PICC\Examples\ex_fat.lst
               ROM used: 27754 bytes (21%)
                         Largest free fragment is 65528
               RAM used: 1381 (37%) at main() level
                         1806 (49%) worst case
               Stack:    17 locations
Executing: "C:\Program Files\PICC\Ccsc.exe" +FH "ex_fat.c" +DF +LN +T +A +M +Z +Y=9 +EA  #__18F4620=TRUE
>>> Warning 202 "ex_fat.c" Line 26(5,8): Variable never used:   rs232_errors
      Memory usage:   ROM=21%      RAM=37% - 49%
      0 Errors,  1 Warnings.
Loaded C:\Program Files\PICC\Examples\ex_fat.cof.
BUILD SUCCEEDED: Sun Jun 12 15:19:29 2011
noyz
PostPosted: Thu Jun 23, 2011 4:46 am     Reply with quote
i figured out that # device - pass string in ram.. must be first line.. before fuses.. Smile
