Redirectable PINs and UART
Will Reeve
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
PostPosted: Wed Jun 15, 2011 12:41 pm     Reply with quote
Thinking out loud! Can you redirect the pins of a UART on PICs such as the PIC18F27J13 in software? I.E. Can you change the function of the pins on the fly in code, it would be nice to redirect the TX of a hardware UART to different pins for a project I am thinking of!
bkamen
Re: Redirectable PINs and UART
PostPosted: Wed Jun 15, 2011 5:16 pm     Reply with quote
If you are talking about the Peripheral Pin Select, then the answer is "yes".
But you'll need code to change it on-demand like that -- which isn't hard, but I vaguely remember #pin_select didn't play well mid-stream code. (It's good for start up)
I would experiment. Maybe that's changed -- or maybe someone else has some suggestions.
Cheers,
-Ben
PostPosted: Wed Jun 15, 2011 11:16 pm     Reply with quote
By it's preprocessor command nature, the #pin_select statements work only at start-up. To change the pin allocation during run-time, you have to write to the respective peripheral pin-select registers directly.
