help - can't get CCP interrupt to fire (SOLVED)
jumanji
PostPosted: Thu Jun 09, 2011 5:07 pm     Reply with quote
Ok so I have never used interrupts before and I am trying to use the CCP on a 12F615 to determine the width of a pulse. I have looked at examples and tried many different things but I cannot seem to get the interrupt routine to ever run. I put a breakpoint at the top of the interrupt routine and it never gets there. I have a scope probe on the CCP pin and it is getting a valid pulse every 20ms that is about 1ms wide. Here is my code:
#include "12F615.h"
#fuses INTRC_IO,NOWDT,MCLR
#use delay(clock=8000000)
#bit INTF_BIT = 0x0B.1
#define Zero_Cross   PIN_A0
#define Fire_Triac   PIN_A5
#define PWM_In      PIN_A1
// FUNCTION Prototypes
void main(void);
int16 GetRC_PulseWidth(void);
int16 PWMValue;
int16 DutyCycle;
unsigned int16 TriacDelayPeriod;
long rise,fall,pulse_width;
int edgeflag,nop;
//************  Main  ****************************************************************
#int_ccp1
void isr()
   if (edgeflag==1)
         rise = CCP_1;
         setup_ccp1(CCP_CAPTURE_FE);    // now configure CCP1 to capture falling
      edgeflag=0;
      fall = CCP_1;
         setup_ccp1(CCP_CAPTURE_RE);    // now configure CCP1 to capture rising
      PWMValue = fall - rise;
      edgeflag=1;
void main ( )
   int16 i;
   set_tris_a(0x0f);
   PWMValue = 182;
   fall=0;
   rise=0;
   edgeflag=1;
   SETUP_ADC(No_Analogs),
   setup_ccp1(CCP_CAPTURE_RE);    // Configure CCP1 to capture rise
      setup_timer_1(T1_INTERNAL);    // Start timer 1
      enable_interrupts(INT_CCP1);   // Setup interrupt on falling edge
   nop=1;
   do {
      if (PWMValue >100)
         //do something
         // do something else
   }while (1);
PostPosted: Thu Jun 09, 2011 5:24 pm     Reply with quote
What's the Vdd voltage of the PIC and what are the voltage levels of
the waveform going to the CCP1 pin ?
And what's your compiler version ?
jumanji
PostPosted: Thu Jun 09, 2011 5:25 pm     Reply with quote
Vdd = 5V and the pulse is 5V.
jumanji
PostPosted: Thu Jun 09, 2011 5:28 pm     Reply with quote
sorry - compiler is v4.121
PostPosted: Thu Jun 09, 2011 7:44 pm     Reply with quote
Try setting the OPTION register to disable pin GP2 as the Timer0 clock
source, as shown in this post:
http://www.ccsinfo.com/forum/viewtopic.php?t=33336&start=3
jumanji
PostPosted: Fri Jun 10, 2011 6:22 am     Reply with quote
ok-I tried that but it doesn't make any difference.
I don't know if it makes any difference, but I should mention that I am using the header board that plugs into the debugger (ICD3) and allows you to debug with the 12F615 and not give up the use of the 2 pins needed for programming.
PostPosted: Fri Jun 10, 2011 4:11 pm     Reply with quote
I don't have a 12F615. I do have 12F683 and it's similar. I made the
following test program to blink an LED if I get a CCP1 interrupt when I
press a switch. It works. I get a short blink on the LED every time I
push down the switch. This was tested with vs. 4.121.
Here's the switch circuit:
           +5v
            > 10K
            <         ___  Switch
To PIC      |        _|_|_
pin 5  --------------o   o------
(GP2)                          |
                              --- GND
Here is the LED circuit. You can also use 330 or 470 ohms for the resistor.
To PIC
pin 2     220 ohms      LED
(GP5) ---/\/\/\/------->|----
                          -----  Ground
Here's the test program.
#include <12F683.H>
#fuses INTRC_IO, NOWDT, BROWNOUT, PUT, NOMCLR
#use delay(clock=4M)
#int_ccp1
void ccp1_isr(void)
output_high(PIN_A5);
delay_ms(200);         // Do a short blink on the LED
output_low(PIN_A5);
#define set_options(value)   {#ASM         \
                              MOVLW  value \
                              OPTION       \
                              #ENDASM}
set_options(0xC0);
clear_interrupt(INT_CCP1);
jumanji
PostPosted: Fri Jun 10, 2011 4:56 pm     Reply with quote
Thank you for going through the trouble to do this. What hardware are you using to test this? Are you using a debugger or actually programming a device? I have continued to work with this and I have discovered that if I run my code on the simulator that it works - but using the ICD3 and the header board the INTF bit gets set as soon as I enable the interrupts and I am unable to clear it and it never jumps to the isr routine.
PostPosted: Fri Jun 10, 2011 5:03 pm     Reply with quote
I used a 3M solderless breadboard. I plugged wires and components into
it to make the circuits. I used a PicKit2 programmer to program the PIC
and to supply power to the board. I compiled and programmed the code
in "Release" mode in MPLAB. I just ran it in "standalone" mode, not in
debug mode.
jumanji
PostPosted: Fri Jun 10, 2011 5:36 pm     Reply with quote
I am convinced the problem is not the code but somewhere in my debugger setup. I have contacted Microchp to see if this is a known issue. In the meantime I will program an actual device and verify that it is working without the debugger. Thanks again for your help on this.
jumanji
PostPosted: Fri Jun 10, 2011 6:07 pm     Reply with quote
ok- just programmed a device and added some code to pulse a pin if I go thru the isr routine and it is working fine. There is definitely something wrong within the debugger system somewhere....
jumanji
PostPosted: Mon Jun 13, 2011 1:22 pm     Reply with quote
Just got a nice email from Microchip. Apparently if you dig into the "limitations" section of MPLAB for this family of devices you find this note: "ECCP capture mode interrupts do not occur when emulating the PIC12F615 and PIC12F617 devices".
Bloody hell.
