passing constant array pointer to function
hello188
PostPosted: Fri Jun 10, 2011 11:40 am     Reply with quote
Hi, I want to make a function that takes a variable length constant arrays.
I tried doing following
const int8 a[10];
const int8 b[3];
void function(int8 c[]){
//do something here
and call the function by
function(a);
However, the compiler gives me the error
Error 90 "main.c" Line 27(15,20): Attempt to create a pointer to a constant
I want to put the array in ROM as the data is too big to store in RAM.
Thank you
vinniewryan
PostPosted: Fri Jun 10, 2011 12:23 pm     Reply with quote
Check page 48 (pdf pg.60) in the CCS manual. It is possible to create a pointer to a constant. What is your compiler version?
Vinnie Ryan
PostPosted: Fri Jun 10, 2011 12:56 pm     Reply with quote
Also post your PIC.
hello188
PostPosted: Fri Jun 10, 2011 1:52 pm     Reply with quote
my compiler version is
4.120
and PIC is
18F46K22
Thanks guys
hello188
PostPosted: Fri Jun 10, 2011 2:11 pm     Reply with quote
I found below example on CCS website
const char version[] = "PRODUCT ID V1.01";
const char *ptr;
However, it won't compile for some reason
Please help!!
Thank you
hello188
PostPosted: Fri Jun 10, 2011 2:13 pm     Reply with quote
gives
Error 46 "F:\Jae\Software\Developing\IOJN\RCU890\def_var.h" Line 18(16,17): Expecting an =
PostPosted: Fri Jun 10, 2011 2:21 pm     Reply with quote
I posted an example of how to use 'rom' pointers in this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=45132
It works with your PIC with vs. 4.120.
hello188
PostPosted: Sun Jun 12, 2011 12:48 am     Reply with quote
Thanks that post helped me a lot
However, as I code, problem still remains
I am still confused on the behavior of the ROM pointer
I wrote following code, and tested the register contents with debugger
#include<18F46K22.h>
#FUSES HSH, NOPLLEN, NOIESO, PUT, NOBROWNOUT, NOWDT, NOPBADEN, MCLR, STVREN, NODEBUG
rom int8 HELLO[5] = {'H','E','L','L','O'};
int8 debug_array[5]= {0,0,0,0,0};
int8 debug1 = 0;
int8 debug2 = 0;
int8 debug3 = 0;
int8 debug4 = 0;
void fun(rom *c){
   int8 k;
   for(k=0;k<5;k++) debug_array[k] = c[k];
   debug1 = debug_array[0];
   debug2 = c[0];
   debug3 = debug_array[1];
   debug4 = c[1];
   k = 1;
   debug5 = c[k];
void main(void){
   fun(HELLO);
and i get following results
debug_array = HELLO; //copied exactly same.
debug1 = 'H';
debug2 = 'H';
debug3 = 'E';
debug4 = 0;
debug5 = 'E';
debug4 should have been 'E' too. since debug_array[1] = c[k] where k = 1; and debug4= c[1];
I don't understand
what is the difference betweeen addressing array using variable and constant?
Thanks for helping guys
PostPosted: Mon Jun 13, 2011 9:23 am     Reply with quote
What you post doesn't work, since you only declare debug1 to 4, yet use debug5. Suggest you keep the actual posting and test code the same. Probably a similar fault is causing the problem....
