Rotate 2 byte
pilar
Rotate 2 byte
PostPosted: Thu Jun 09, 2011 3:33 pm     Reply with quote
Hi someone can tell me how I can rotate 2 bytes?
Example: I hace 0xFD45 I need to have 0x45FD
PostPosted: Thu Jun 09, 2011 4:20 pm     Reply with quote
You can use a swap_bytes() macro. It displays this result:
initial value = 1234
result = 3412
Here's the test program:
#include <16F877.H>
#fuses XT, NOWDT, BROWNOUT, PUT, NOLVP
#define swap_bytes(x)  make16(x, x >> 8)
int16 result;
int16 value;
value = 0x1234;
printf("initial value = %lx \n\r", value);
result = swap_bytes(value);
printf("result = %lx \n\r", result);
PostPosted: Thu Jun 09, 2011 4:33 pm     Reply with quote
A byte swap can be effectively performed with built-in functions
ival16 = make16(make8(ival16,0),make8(ival16,1));
pilar
PostPosted: Thu Jun 09, 2011 5:07 pm     Reply with quote
Thank you...
