leevise
about #define PORTB 0x6 and #byte RB=6 question |
Posted: Wed Jun 08, 2011 11:40 pm |
Hello, everyone,
I meet a question, and it puzzle me that # define and # byte difference
when i use the "#define PORTB 0x6;" the DEMO program is success.
Detail info. as follow:
#include <16f877a.h>
//#device icd=ture
#fuses HS,NOWDT,PUT,NOPROTECT
#use delay(CLOCK=10000000)
#define PORTA 0x5
#define PORTB 0x6
#define PORTC 0x7
#define PORTD 0X8
#use fast_io(D) //set IO
int i,led;
set_tris_d(0x00);
*PORTD=0x00;
led=0x01;
for(i=0;i<8;i++)
*PORTD=led;
led=led<<1;
But I change the "#define "to "#byte", the program is failure.
Program as follow:
//#device icd=ture
#byte RA = 5
#byte RB = 6
#byte RC = 7
#byte RD = 8
#byte RE = 9
int i,led;
set_tris_d(0x00); //set io direction
*RD=0x00;
led=0x01;
for(i=0;i<8;i++)
*RD=led;
led=led<<1;
Who can explain it to me ?
Thank you very much! |
Fusillade
Posted: Thu Jun 09, 2011 6:14 am |
When using #byte, such as #byte RD = 8, it is defining a name for memory location 8. So when using #byte, do not use *RD = 0x00; instead, just assign the value directly to the memory location: RD = 0x00. _________________ New:
Compiler Version: 5.078
IDE Version: MPLAB X V4.15
Devices: PIC18LF****
Old:
Compiler Version: 4.121
IDE Version: MPLAB IDE V8.63
Devices: PIC18LF**** |
Posted: Thu Jun 09, 2011 8:12 am |
Yes.
They are very different things.
#define is the 'macro language' for C. it allows you to 'define' a block of text to replace another block of text. has some quite powerful features that are very rarely used. So the line:
#define PORTB 0x6
simply creates a text substitution, where wherever you type 'PORTB', the number '0x6' is substituted. On a lot of C's, you can look at the output after this bit of processing is done, and if you did so, in the first use of PORTD in your example, you would see:
*0x6 = 0x00;
There is a caveat in the substitution, which is that it can be 'bad practice not to use brackets. The problem is that in some cases the substitution won't give the expected results. The classic example in K&R, is a macro:
#define square(x) x*x
which if you perform with a mathematical value like 2+3, gives:
square(2+3) -> evaluates to 2+3*2+3
which since multiplication is performed before addition, solves as 11.....
Better to always 'bracket' numbers and values used inside macros.
#byte, is a very different beast. It allows you to locate a variable _at_ a memory location. If no variable exists with the name, a byte sized one is created.
So:
#byte PORTB=0x6
creates a byte variable 'PORTB', which uses the memory _at_ location 6 in the RAM. So if you use:
*PORTB=0;
You would read the memory value at location six (whatever PORTB, was last set to - 0xFF on boot....), and use this number as the address to write '0' to. Corrupting the memory at this location.
To write to location 6, simply needs:
PORTB=0;
It is worth realising that the function also allows you to put 16bit variables (or even larger) at a location. So:
int16 two_ports;
#byte two_ports=0x5
Creates a 16bit variable 'two_ports' sitting at locations 5, and 6 in the memory.
litledan
Posted: Fri Aug 16, 2013 12:17 pm |
Thank you very much for the explanation Ttelmah, it helped me a lot ;) |
