Problem sending command from 16F877 to GPRS modem
WildLife
PostPosted: Wed Jun 08, 2011 8:21 pm     Reply with quote
Hi guys, first post here Smile
I'm trying to communicate my 16F877 with a GPRS modem (ADH8066 with the evaluation board from sparkfun).
I'm using the following code:
#include <16F877A.h>
#fuses HS,NOWDT,NOLVP,PUT,NOPROTECT,NOBROWNOUT,NOWRT
#use rs232(baud=115200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=GPRS,ERRORS)
#define BUFFER_SIZE 32
BYTE buffer[BUFFER_SIZE];
BYTE next_in = 0;
BYTE next_out = 0;
#define bkbhit (next_in!=next_out)
char cmd_str[20];
byte bgetc()
   byte c;
   while(!bkbhit) ;
   c=buffer[next_out];
   next_out=(next_out+1) % BUFFER_SIZE;
   return(c);
#int_rda
void serial_received()
   int t;
   buffer[next_in]=getc();
   t=next_in;
   next_in=(next_in+1) % BUFFER_SIZE;
   if(next_in==next_out)
     next_in=t;           // Buffer full !!
void init()
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_spi(FALSE);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   enable_interrupts(INT_RDA);
   output_high(GSM_ONKEY);
   output_high(GSM_CTS);
   output_high(GSM_DSR);
   output_low(GSM_LED);
int startGSM()
   delay_ms(200);
   output_low(GSM_ONKEY);
   delay_ms(2000);
   delay_ms(300);
   output_low(GSM_CTS);
   output_low(GSM_DSR);
   delay_ms(4000);
   //ler ready!
   return 1;
void testePrintGSM()
   fprintf(GPRS,"AT\n");
   int8 cont = 0;
   unsigned char a;
   init();
   timeout(5);
   output_high(GSM_LED);
   startGSM();
   timeout(15);
   while(true)
      // Searches for 'ady' from the word Ready witch means modem has reset
      if (bkbhit)
      a = bgetc();
      if (a == 'a')
         a = bgetc();
         if (a == 'd')
         a = bgetc();
            if (a == 'y')
            timeout(3);
            testePrintGSM();
      // Searches for OK, reply from the command fprintf(GRPS,"AT\n")
      else if (a == 'O')
         a = bgetc();
         if (a == 'K')
      delay_ms(50);
Sorry for the big code, anyways, I'm able to read from the modem the "Ready" reply, but I can't read the OK reply, so I assume I'm not being able to send the "AT\n" command. Any ideas?
BTW I've already tried fprintf, putc, and so on, with no luck :/
Thanks,
WildLife
PostPosted: Wed Jun 08, 2011 9:13 pm     Reply with quote
Your final character is a newline, but the modem expects a carriage
return, which is a \r.
WildLife
PostPosted: Thu Jun 09, 2011 8:59 am     Reply with quote
That might have saved me some hassle in the future, but still it isn't working :(
Any other thoughts?
