Nepersky
A *3* error |
Posted: Wed Jun 08, 2011 4:05 am |
Hello!
When compiling a simple program showed bellow, I am constantly getting the following error:
Quote: | --- Info 300 "[file directory]\16F1827.h" Line 2(9,15): More info: *3* Error
*** Error 44 "[file directory]\16F1827.h" Line 2(9,15): Internal Error - Contact CCS OUTPUT FILE 1 Errors, 0 Warnings.
The line 2 in the 16F1827.h file is #device PIC16F1827.
The simple program is:
Code: | // main .c file
#include "16F1827.h"
int i=0;
i++;
i++;
i--;
i--;
Can anyone offer any help with this? I can not find any description of the *3* error. And the output error file only consists of the quote I wrote above. Is there any other output file which holds additional information about what went wrong?
If I make the same program with PIC18F24J11 it works. So instead of #include "16F1827.h" I write #include "18F24J11.h".
The program was written in MPLAB and the compiler versions are 4.112 (IDE,PCB,PCM) and 4.121 (PCH)
Thank you in advance for all your help.
Cheers!
[EDIT]: I tried to use PCW instead of MPLAB and I get the same error with some further explanation: Cannot open file "C:\PICC\tmp-test\test.esym". The process cannot access the file because it is being used by another proccess.
[EDIT - further testing]: I tried some other PICs and the problem seems to be limited to PIC16Fs. With 18Fs it seems to work. Before I tried 18F24J11 and now I also tired the PIC18F26J53. It works. With PIC16F1827, PIC16F1826 and PIC16F1933 the problem exists. |
heUAcyp
header file |
Posted: Wed Jun 08, 2011 9:59 am |
Are you sure you include the header file of PIC 16F1827 in .mcw ? Just changing the #include isn't enough |
Nepersky
Posted: Wed Jun 08, 2011 10:51 am |
I am not sure what the.mcw is. How do I check if it is included correctly?
But I think that it should be, because I started the project with the project wizard, where I gave the right PIC. Also, when going to conigure-select device, the right chip is already chosen in the device field.
And when changing between different PICs from 18F series, it works. And I always take the same steps (with 16F and 18F).
Still, I would appreciate any clarification regarding the .mcw file.
Cheers! |
