Help with I2C - 16F88 and WII Motion Plus (Accelerometers)
soko
PostPosted: Sun Jun 05, 2011 12:07 pm     Reply with quote
Hello!
I'm trying to read an I2C device, exactly one of the Wii Nunchuk, to get data from your accelerometers, but no way to compile the following code.
#include <16f88.h>                  //pic a utilizar
#fuses NOWDT,NOPROTECT,PUT,NOLVP, NOMCLR,INTRC_IO     //ordenes para el programador
#use delay (clock=8000000)            //Fosc=8Mhz
#define use_portb_lcd TRUE          //definir portb lcd
#include<LCD.c>                     //libreria manejo lcd
#use I2C (SLAVE,SDA=PIN_A1,SCL=PIN_A0,ADDRESS=0X52,SLOW,FORCE_HW)
void main(void){                        // FUNCION PRINCIPAL
      setup_oscillator(OSC_8MHZ|OSC_INTRC);       // Activa el oscilador interno.
   set_tris_b(0x00);                     //Puerto B como SALIDA.
   long dato;
   while(true){
        if(i2c_poll()) {
         dato=i2c_read();
         lcd_gotoxy(1,1);
         printf(lcd_putc,"Valor:");
         lcd_gotoxy(1,2);
         printf(lcd_putc,"%03lu",dato);
         delay_ms(300);
This is the error:
Executing: "C:\Archivos de programa\PICC\Ccsc.exe" +FM "WOOKO_V5.c" #__DEBUG=1 +ICD +DF +LN +T +A +M +Z +Y=9 +EA #__16F88=TRUE
*** Error 12 "WOOKO_V5.c" Line 14(17,18): Undefined identifier -- i2c_poll
1 Errors, 0 Warnings.
Halting build on first failure as requested.
BUILD FAILED: Sun Jun 05 19:52:09 2011
you can help me with this problem?, thanks
PostPosted: Sun Jun 05, 2011 12:18 pm     Reply with quote
the function 'i2c_poll()' is not recognized by the compiler. Perhaps it is a function contained within a 'header' or 'devices' file similar to the #include lcd.c that you added for the LCd functions ?
or if
it is a valid compiler function, perhaps you've mistyped it or it needs additional information.
If you press F11 while in MPLAB, the CCS HELP pages will appear, consult them or the manual for further information !!
PostPosted: Sun Jun 05, 2011 2:10 pm     Reply with quote
Read the manual:
i2c_poll( )
Syntax:
i2c_poll()
i2c_poll(stream)
Parameters: stream (optional)- specify the stream defined in #USE I2C
Returns:
1 (TRUE) or 0 (FALSE)
Function: The I2C_POLL() function should only be used when the built-in SSP is used.
Pins A0 and A1 are not the hardware SSP pins:
The hardware i2c pins on the 16F88 are Pin B1 for SDA, and Pin B4 for SCL.
soko
PostPosted: Sun Jun 05, 2011 4:12 pm     Reply with quote
Thank you very much.
I'll try the settings and then I tell you.
PostPosted: Sun Jun 05, 2011 4:56 pm     Reply with quote
Also I noticed that you're using the CCS LCD driver on Port B. If you use
the hardware i2c pins, you can't use all of Port B for the LCD. You can
use other pins for the LCD if you use a modern CCS lcd driver, or if
you use the Flex driver. For example, you could use some pins on Port A
and some pins on Port B (other than B1 and B4) for the LCD:
http://www.ccsinfo.com/forum/viewtopic.php?t=24661
soko
PostPosted: Tue Jun 07, 2011 7:28 am     Reply with quote
hello again!
Thanks to your help, I have working examples with i2c, but the program still works fine.
According to specifications of this website:
http://wiibrew.org/wiki/Wiimote/Extension_Controllers#Wii_Motion_Plus
I programed this code, but it hangs at the instruction:
      i2c_start();
      i2c_write(0xA5);   // leo valores WMP
Some friendly advice?
Thanks and sorry for my English because I'm not native.
#include <16F88.h>
#FUSES NOWDT                     //No Watch Dog Timer
#FUSES INTRC_IO                     //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES PUT                        //No Power Up Timer
#FUSES NOMCLR                     //Master Clear pin used for I/O
#FUSES NOPROTECT                  //Code not protected from reading
#FUSES NOCPD                     //No EE protection
#FUSES BROWNOUT                     //No brownout reset
#FUSES IESO                        //Internal External Switch Over mode enabled
#FUSES FCMEN                     //Fail-safe clock monitor enabled
#FUSES NOLVP                     //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NODEBUG                     //No Debug mode for ICD
#FUSES NOWRT                     //Program memory not write protected
#FUSES RESERVED                     //Used to set the reserved FUSE bits
#use delay(clock=8000000)
#use i2c(Master,sda=PIN_B1,scl=PIN_B4,fast)
#include <LCD_PORT_A.c>                   //libreria manejo lcd
int t,i;
int datos[6] = {0};                  // Valor en exadecimal
int16 yaw=0,pitch=0,roll=0;            // Lecturas WMP
void inicio_wm() {
   i2c_start();
   i2c_write(0xA6);
   i2c_write(0xF0);
   i2c_write(0x55);
   i2c_stop();
   delay_ms(1);
   i2c_write(0xA6);
   i2c_write(0xFE);
   i2c_write(0x05);
   i2c_stop();
void LCD(){
   lcd_gotoxy(1,1);
   printf(lcd_putc,"Yaw- Roll -Pitch");
   lcd_gotoxy(1,2);
   printf(lcd_putc,"%02u%02u-%02u%02u-%02u%02u",datos[0],datos[1],datos[2],datos[3],datos[4],datos[5]);
   delay_ms(30);
void main() {
   setup_adc(ADC_CLOCK_DIV_2);
   setup_timer_1(T1_DISABLED);
   inicio_wm();
   delay_ms(10);
   while(1) {
      i2c_start();     //Preparamos WMP para pedir datos
      i2c_write(0xA4);
      i2c_write(0x00); //Se manda 0 antes de cada peticiĆ³n de datos
      delay_ms(1);
      i2c_start();
      for (t=0;t<5;t++)
         datos[t] = i2c_read();
      datos[5] = i2c_read(0);
      i2c_stop();
      LCD();
PostPosted: Tue Jun 07, 2011 8:41 am     Reply with quote
well my Spanish isn't good to read the comments !
... but...
do you have the proper value pullups on the I2C lines ?
soko
PostPosted: Tue Jun 07, 2011 8:59 am     Reply with quote
Ok, sorry.
Here is the translated code, I hope to be better.
The pull-up resistors are integrated in the device itself, have a value of 2k2.
Thanks for the advice.
int t;
int datos[6] = {0};                  // DATA READ
void inicio_wm() {                      // WII MOTION PLUS DATA CONTROL
   i2c_start();
   i2c_write(0xA6);
   i2c_write(0xF0);
   i2c_write(0x55);
   i2c_stop();
   delay_ms(1);
   i2c_write(0xA6);
   i2c_write(0xFE);
   i2c_write(0x05);
   i2c_stop();
void LCD(){
   lcd_gotoxy(1,1);
   lcd_gotoxy(1,2);
   delay_ms(30);
void main() {
   inicio_wm();
   delay_ms(10);
   while(1) {
      i2c_start();     //INICIALIZE WII MP
      i2c_write(0xA4);  // DIRECCION OF WMP
      i2c_write(0x00); //SEND 0
      delay_ms(1);
      i2c_start();
      i2c_write(0xA5);   //READ WMP OUT VALUES
      for (t=0;t<5;t++)  // BUFFER VALUES IN A VECTOR OF 6 DATAS
      i2c_stop();       // STOP I2C
      LCD();             // PRINT DATAS
PostPosted: Tue Jun 07, 2011 12:31 pm     Reply with quote
Run this program. It will list all devices on the i2c bus that it can find.
See if it detects your Nunchuck. What does it show ?
http://www.ccsinfo.com/forum/viewtopic.php?t=42368&start=4
Modify top few lines of the program (#include statement, etc.) to fit
your 16F88 setup.
soko
PostPosted: Tue Jun 07, 2011 2:03 pm     Reply with quote
It works!!! Laughing Laughing
Thank you very much everyone !!!!! At the end with your advice and get directions program has worked.
Also find information on this website, where you can see the code that works.
http://www.todopic.com.ar/foros/index.php?topic=30669.0
Greetings and thanks. Wink
gogutier
PostPosted: Mon Apr 30, 2012 11:09 pm     Reply with quote
very useful, thanks!
