PIC 32 Microcontroller
ronski
PostPosted: Mon Jun 06, 2011 10:50 am     Reply with quote
I am trying to program a microcontroller in such a way that, when switch 1 is pressed the red led will turn ON, and when I press the switch 1 again, the red led will switch off, and then the yellow led will switch on when the switch 1 on pic32 microcontroller is pressed. I was wondering if any1 know how to use a counter to keep track of the number of times the switch has been pressed. This is all I could write, I will really appreciate if someone will br able to help me out
/* Switch and Traffic Light exercise*/
/* Adds support for PIC32 Peripheral library functions and macros */
#include <plib.h>
#include <p32xxxx.h>
#include <GenericTypeDefs.h>
#define RedLedON()         mPORTDSetBits (BIT_0)
#define RedLedOFF()         mPORTDClearBits (BIT_0)
#define YellowLedON()      mPORTDSetBits (BIT_1)
#define YellowLedOFF()      mPORTDClearBits (BIT_1)
#define GreenLedON()      mPORTDSetBits (BIT_2)
#define GreenLedOFF()      mPORTDClearBits (BIT_2)
const int SW1 = BIT_6;
//#define SW1ON            mPORTDSetBits (BIT_6)
//#define SW1OFF         mPORTDClearBits (BIT_6)
//#define SYS_FREQ      (80000000)
//void Timing(unsigned int);
int main()
mPORTDSetPinsDigitalIn(BIT_6);
mPORTDSetPinsDigitalOut(BIT_0 | BIT_1 | BIT_2);
int n;
int i;
while(1) {
for (i = 0; i < 5; i++)
n = mPORTDReadBits (SW1);
if (n) mPORTDClearBits(BIT_0);
mPORTDSetBits(BIT_0);
return 0;
dyeatman
PostPosted: Mon Jun 06, 2011 11:01 am     Reply with quote
You are in the wrong place... You posted Microchip C code and this is the
CCS C forum. The two compilers are not compatible.
You need to go to the Microchip forum:
http://www.microchip.com/forums/
Google and Forum Search are some of your best tools!!!!
