dsPIC PLL settings
szkrep
dsPIC PLL settings
PostPosted: Wed Jun 01, 2011 7:37 am     Reply with quote
Hi all,
I am trying to use a dsPIC33FJ256MC710A. I managed to blink some led, etc, but clock frequency is always incorrect (delays are far from what i wanted).
I checked the .h file of the device for usable fuses, but none of them match the names which can be found in the datasheet. http://ww1.microchip.com/downloads/en/DeviceDoc/70594C.pdf <- On page 147 in this document, everything seems to be clearly written, but in CCS what fuses mean them?
In the help file of CCS I tried to find some special setting in setup_oscillator(), but I couldn't figure out how to set the PLL correctly.
I want to use the device at 80MHz from external crystal (currently 10MHz is built in because of the datasheets good-looking explanation). Could someone post an example, or an explanation about relating CCS fuse names?
PostPosted: Thu Jun 02, 2011 4:39 am     Reply with quote
Most of this is not fuses.
Key is that on wake up, the incoming oscillator _must_ be less than 8MHz, if the PLL is used. So the unit has to start up on the internal clock, and only then change to the external clock (section 2.7). The compiler can do this for you, if you simply tell it in the clock statement to use an external 10MHz crystal, and a clock of 80MHz. It then calculates the PLL divisions for you, and adds the code to generate these. The CKFSM fuse is needed to allow this.
