Setup Multiple ADC Ports
edbfmi1
PostPosted: Thu May 26, 2011 10:57 am     Reply with quote
I am using PCM Version 4.089
I am converting code from a PIC16F73 chip to run on a PIC16F723A.
The old code used the following to setup the analog ports:
SETUP_ADC_PORTS(AN0_AN1_AN3);
Pins A2 and A5 are digital outputs and Pin A4 is not used.
When it gets to this line I get the following error.
Undefined identifier AN0_AN1_AN3
I went to the PIC16F723.h file and see that it references the analog ports as sAN0 sAN1 etc. so I changed the code to the following
SETUP_ADC_PORTS(sAN0_sAN1_sAN3);
I get the same "Undefined identifier" error message
Undefined identifier sAN0_sAN1_sAN3
The last thing I tried was the following
SETUP_ADC_PORTS(sAN0|sAN1|sAN3);
This did not give a compile error but the analog inputs are not being read properly.
Any help on what I am doing wrong would be appreciated.
cerr
PostPosted: Thu May 26, 2011 12:23 pm     Reply with quote
How do you read them, this is the correct setup method.
Ron
edbfmi1
PostPosted: Thu May 26, 2011 12:48 pm     Reply with quote
Hi Ron,
They are read in the following subroutine
void read_pots()            // Get current pot values
      SETUP_ADC(adc_clock_div_8);
      set_adc_channel(0);         // Hardness Pot  Analog Channel 0
      delay_ms(2);
      temp_ad = read_adc();
      delay_cycles(1);
      delay_cycles(1);
      hard_in = temp_ad;
      hard = temp_ad*7;      // Soft to Hard adjustment = 0 to 1275uSec
      set_adc_channel(3);         // Delta Pot ("Offtime")  Analog Channel 3
      delay_ms(2);
      delay_cycles(1);
      delta_in = temp_ad;
      delta = 0;
      hard_in = ~hard_in;      //The following lines fit a variable delta
      delta = hard_in;      //relative to the hardness setting
      delay_cycles(1);
      delta = delta*delta;
      delay_cycles(1);
      delta >>= 8;         //Divide by
      delta = delta + 1;      //255
      delay_cycles(1);
      delta = delta*3;
      delay_cycles(1);
      delta >>= 1;         //Divide by
      delay_cycles(1);
      delta = delta + delta_in;
      delay_cycles(1);
      if (delta <= 4) delta = 4;   // delta must be >0
      delay_cycles(1);
      onethirddelta = delta/3;
      delay_cycles(1);
      twothirddelta = onethirddelta;
      twothirddelta <<= 1;
      delay_cycles(1);
      total = fixed_os + offset + hard + delta;   // total hardness band
      delay_cycles(1);
      compoff = fixed_os + offset + hard;   // comprressor off value
Thanks,
Ed
PostPosted: Thu May 26, 2011 1:01 pm     Reply with quote
The setup_adc_ports() function is messed up in your compiler version.
You need to setup the registers manually.
edbfmi1
PostPosted: Thu May 26, 2011 1:21 pm     Reply with quote
Do you know if it is not "messed up" on the latest version of the PCW compiler? I am looking at upgrading from the PCM to PCW.
edbfmi1
PostPosted: Thu May 26, 2011 1:29 pm     Reply with quote
Hi PCM programmer,
I guess I really need to ask if the latest version of PCM has the setup_adc_ports() function fixed. I will get the latest version of the PCM compiler if it is corrected since I use MPLAB IDE.
Thanks,
Ed
PostPosted: Thu May 26, 2011 3:19 pm     Reply with quote
The generated code looks OK for compiler vs. 4.121. There is a minor
bug in the 16F723A.h file. Notice that it's missing the bitmask for sAN1.
The top byte should be 0x02 for sAN1 below:
#define sAN0          0x01000000    // A0
#define sAN1          0x00000000    // A1  <=== Missing the bitmask
#define sAN2          0x04000000    // A2
#define sAN3          0x08000000    // A3
#define sAN4          0x20000000    // A5
But you can easily edit the .h file and fix that. I'll email CCS and tell
them about the problem.
There is another small problem in the compiler start-up code. They
write 0x00 to RAM addresses 0x188 and 0x189. That's for ANSELD
and ANSELE, but those registers don't exist on the 16F723A. So it's
a bug, but it doesn't matter. There's no SFR register there, so writing
0x00 to it doesn't hurt anything. I'll tell CCS about that one too.
I reviewed the .LST file and it looks OK, but it's possible that I made
some mistake. In other words, I don't work for CCS, so I don't absolutely
guarantee that your code will run on this PIC.
Here's the test file that I used:
#include <16F723A.h>
#fuses INTRC_IO,NOWDT,NOPLLEN,VCAP_A6
int8 result;
setup_adc_ports(sAN0 | sAN1 | sAN3);
setup_adc(ADC_CLOCK_DIV_8);
set_adc_channel(0);
delay_us(10);
result = read_adc();
set_adc_channel(1);
delay_us(10);
set_adc_channel(3);
delay_us(10);
edbfmi1
PostPosted: Thu May 26, 2011 4:32 pm     Reply with quote
Thank you PCM programmer!
I hope you get some sort of "show of appreciation" from CCS for all the effort you put into these forums.
I will take a look at what you found in the morning when I get back into the office.
Thanks again.
edbfmi1
PostPosted: Fri May 27, 2011 1:02 pm     Reply with quote
PCM programmer - You are a Rock Star!!!!
I downloaded the latest PCM version 4.121 and tweaked the PIC16F723a.h file like you said and it worked perfect.
Thanks again for all you help.
(CCS if you monitor this forum you need to put PCM programmer on your payroll Very Happy )
