xbee
Mamat
View user's profile Send private message Yahoo Messenger ICQ Number
xbee
PostPosted: Wed May 25, 2011 2:19 am     Reply with quote
This receive xbee code. Why when I want to receive char 'aa' cannot be successful (x == 'a') ?
#include <18f4620.h>
#fuses HS,NOLVP,NOWDT,NOPROTECT
#use delay(clock=20000000)       // 20 MHz crystal on PCB
//#use rs232(baud=19200, xmit=PIN_A0, rcv=PIN_A1)    // you can use any pins for software uart...
#use rs232(baud=9600, UART1)       // hardware uart much better; uses  RC6/TX and RC7/RX
// characters transmitted faster than the pic eats them will cause UART to hang.
#include <stdlib.h>
char x;
   while (true) {
       if (kbhit()) { x = getc();}
       if (x=='a'){output_high(pin_a0);delay_us(100);}
       else output_low(pin_a0);
PostPosted: Wed May 25, 2011 2:31 am     Reply with quote
First, add the word 'ERRORS' to your hardware UART declaration. This adds code to recover if the UART overflows and avoid hanging....
Then. "aa", is two characters not one.
You need to look for each in turn.
#include <stdlib.h>
char x;
int1 have_first_a=FALSE;
   x=rs232_errors; //This prevents error message from adding 'ERRORS'
   do {
      if (kbhit()) {
         //You should only test when you have a character - hence include here
         //not called continuously as in original code.
         x = getc();
         if (x=='a') {
             if (have_first_a==TRUE) {
                 //Here have seen _two_ consecutive 'a' characters
                 delay_us(100);
                 have_first_a=FALSE;
             else {
                 have_first_a==TRUE; //Flag that one 'a' has been seen
         else {
             have_first_a=FALSE;
             output_low(pin_a0);
   } while(TRUE); //This avoids compiler error message from the while loop
Mamat
PostPosted: Wed May 25, 2011 2:47 am     Reply with quote
when i compile it cannot work
PostPosted: Wed May 25, 2011 7:15 am     Reply with quote
It needs your header added, _with_ the errors keyword.
rnielsen
PostPosted: Wed May 25, 2011 9:05 am     Reply with quote
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,errors,STREAM=UART1)
This will set you serial communications port to use the hardware that's built into the PIC and call it UART1. If you are new to designing with PICs then I strongly advise you use the hardware and not attempt to use software. Use the interrupt:
#int_RDA
void RDA_isr(void)
//  Put code here
to capture your data. Remember, you can only retrieve ONE character at a time, each time the interrupt is entered.
Ronald
PostPosted: Wed May 25, 2011 10:11 am     Reply with quote
He is already using the hardware UART - UART1 sets this up.
You don't need streams unless you have multiple UARTs (software or hardware) in use.
For just looking for "aa", the interrupt is an unnecessary complication. Ideal if he latter wants to do other things at the same time, but for what is shown, gains nothing.
The settings you give are the defaults. It is always 'safer' to use them, but not needed.
