16F877A 40khz pwm
aruna1
16F877A 40khz pwm
PostPosted: Mon May 23, 2011 10:57 am     Reply with quote
Hi
I'm trying to generate 40kHz pwm signal with 50% duty.
Following is the code for 16F877A. It doesn't work, no pwm is generated.
However I can generate 1.227kHz signal. Even 10kHz is not possible. Can someone point me the problem?
My requirement is fixed 40kHz 50% duty pwm signal for ultrasonic transducer. So pwm resolution doesn't matter.
My compiler version is v4.120
#include <16F877A.h>
#device adc=16
#FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
   setup_timer_2(T2_DIV_BY_1,124,1);      //25.0 us overflow, 25.0 us interrupt
   setup_ccp1(ccp_pwm);
   set_pwm1_duty(248);
   output_toggle(PIN_D0);
Thank you
PostPosted: Mon May 23, 2011 11:47 am     Reply with quote
If you use a duty cycle value greater than the PR2 value (which is 124 in
your program), then you will get 100% duty cycle. That's in 8-bit PWM
mode. To force the compiler to use 10-bit PWM mode, you need to tell
the compiler that you're using a 'long' value (16-bits) for the duty cycle.
One way to do this is to add an 'L' at the end of the constant value.
Example:
set_pwm1_duty(248L);
Now it should work. You should see PWM output with your scope.
aruna1
PostPosted: Mon May 23, 2011 11:56 am     Reply with quote
Example:
Hi
I made the correction as you said and now it is working.
but shouldnt wizard do this? is this a bug in compiler? i also noticed that when i set pwm in wizard, it adds
setup_ccp1();
instead of
I have to fill "ccp_pwm" part manually.
and also can you please explain what you just did? I just made the correction but dont know what that really does
thank you
PostPosted: Mon May 23, 2011 12:00 pm     Reply with quote
Don't trust the Wizard.
aruna1
PostPosted: Mon May 23, 2011 12:14 pm     Reply with quote
can you tell me what you did? I dont understand what you said in first post
thank you
PostPosted: Mon May 23, 2011 12:38 pm     Reply with quote
Here's another thread on it. It also has 4 more links at the end for you
to read:
http://www.ccsinfo.com/forum/viewtopic.php?t=17729
aruna1
PostPosted: Mon May 23, 2011 6:50 pm     Reply with quote
to read:
thank you Smile
