PIC24F16K101 UART Problem
dl7vfx
PostPosted: Fri May 20, 2011 3:52 am     Reply with quote
Hello ...
I have a problem with the PIC24F16K101.
UART1 Pin11 and PIN6 is connected to a MAX232, the electronic functions are perfect, at pin 6 of the pic comes to the character from the terminal.
But the pic does not respond with the following code.
He run up to getc and stays there.
In the other direction, that's very good,
characters sent by the controller com on in the terminal program.
#include <main.h>
#include <stdlib.h>
#include "stdio.h"
char c0, c1, c2, c3, c4, c5, c6, c7, c8, c9, d0;
#INT_RDA
setup_adc_ports(ALL_ANALOG,VSS_VDD );
setup_adc(ADC_CLOCK_DIV_4|ADC_TAD_MUL_8);
enable_interrupts(intr_global);
output_bit(pin_b13,1);
output_bit(pin_b15,1);
#use rs232(uart1,baud=9600,parity=N,xmit=PIN_B7,rcv=PIN_B2,bits=8)
c1 = getc();
printf("%c",c1);
output_bit(pin_b13,0);delay_ms(250);output_bit(pin_b13,1);delay_ms(250);
PostPosted: Fri May 20, 2011 4:30 am     Reply with quote
You have #int_rda without any interrupt code.
dl7vfx
PostPosted: Fri May 20, 2011 5:11 am     Reply with quote
Thanks for the answer....,it is right #int rda has nothing to do there
But is not the problem.....
The same code (without #int rda) works on a PIC24FJ128GA010 properly
dl7vfx
PostPosted: Fri May 20, 2011 6:51 am     Reply with quote
Hello ....
the problem is solved....
my extra RS232 PCI card for 2 additional RS232Ports has received but not sent correctly
to the internal com port it works well
greetings ...
