complete newbie question
PostPosted: Thu Mar 04, 2004 6:12 am     Reply with quote
How do i read in from ports.
eg.
i want to right a simple program that counts the number of times a switch on rb0 is pressed and display the output in binary on portc.
i'm using a 16f877 thanks.
SteveS
PostPosted: Thu Mar 04, 2004 8:18 am     Reply with quote
read thru the example programs -
ex_ccp1s.c - shows reading a pushbutton
ex_pbutt.c shows it using interrupts, but you should try polled as a start.
- oh yeah, don't forget about debouncing the switch!
- SteveS
jds-pic2
Re: complete newbie question
PostPosted: Thu Mar 04, 2004 8:19 am     Reply with quote
eg.
set up an interupt on rb0. if there is no HW support to do so you will have to sit and continuously poll the pin. after your overall measurement interval expires, output the value to the target port by employing a #BYTE directive. there are examples of both these issues in the CCS manual.
how will you handle switch debouncing? in HW, SW, or both?
jds-pic2
tong143
PostPosted: Fri May 13, 2011 1:55 am     Reply with quote
- SteveS
Please tell me where I can fine the ex_pbutt.c program
SherpaDoug
PostPosted: Fri May 13, 2011 7:08 am     Reply with quote
It should be in your examples folder. On my PC it is here:
C:\Program Files\PICC\Examples
but the path may vary depending on your compiler installation.
If you are just starting to learn to program you should try polling first, before using interrupts.
tong143
PostPosted: Fri May 13, 2011 7:47 am     Reply with quote
Please give me information on where to find literature and examples on polling
tong143
PostPosted: Fri May 13, 2011 7:50 am     Reply with quote
Shall you help on topic posted under http://www.ccsinfo.com/forum/viewtopic.php?p=147631#147631
