Help PWM in PIC16F684
jorsang2
PostPosted: Thu May 12, 2011 8:51 am     Reply with quote
Hi !
I have a problem with PIC16F684.
I would like to activate and see PWM in Proteus, but it doesn't work.
This is the code (partial code) :
#include <16F684.h>
#device adc=10
#FUSES WDT
#FUSES HS
#FUSES NOCPD
#FUSES NOPROTECT
#FUSES PUT
#FUSES BROWNOUT
#use delay(crystal=20000000)
   restart_wdt();
   set_timer0(1);       // poner el timer0 a 1
   setup_adc_ports(ALL_ANALOG);
   setup_adc(ADC_CLOCK_DIV_2);
   setup_timer_0(T0_EXT_L_TO_H|T0_DIV_1);
   setup_timer_1(T1_DISABLED);
   setup_comparator(NC_NC);
    setup_wdt(WDT_2304MS);
   setup_timer_2(T2_DIV_BY_1,100,1); // Fpwm=50 kHz
   setup_ccp1(CCP_PWM);
   set_pwm1_duty(50);
   restart_wdt();
   set_timer0(1);
for (;;)
      set_pwm1_duty(30);
      restart_wdt();
      set_timer0(1);
      delay_us(800);
Please, could someone help me?
This code is now working (in proteus) in others PICs. I don't know why is not working with this PIC, I think maybe the fault is the simulator ...
Thanks in advance Smile
PostPosted: Thu May 12, 2011 1:23 pm     Reply with quote
Always post your compiler version. Your version may have bugs.
If you post your version, then we (forum members) can look for
bugs in the ASM code.
PostPosted: Thu May 12, 2011 2:53 pm     Reply with quote
Proteus, like all other simulators, is FULL of bugs.....
Get real PICs,wire them up and test in the real world.
You'll be a LOT happier !!
jorsang2
PostPosted: Fri May 13, 2011 3:22 am     Reply with quote
CCS PCM C Compiler, Version 4.104, 5967
