znses
Sleep Mode PIC16F877 |
Posted: Tue May 10, 2011 8:44 am |
How can I configure a sleep mode for PIC16F877 and how to quit from sleep mode in order to enable the PIC to read from the sensors.
Can anyone help me in formulating a code for doing that. |
Gabriel
Posted: Tue May 10, 2011 10:02 am |
hi,
You need to have an interrupt to wake up from the sleep mode.
You may do so by using pin B0 (specific interrupt pin), or port_B interrupts on change, or (im not sure) timer interrupts.
You need to set up the interrupt servce routine (ISR), enable interrupts.
You need something to provide the external interrupt signal,
a RTC, a control signal, a comparator, a 555 timer, what ever.
G. _________________ CCS PCM 5.078 & CCS PCH 5.093 |
Posted: Tue May 10, 2011 11:44 am |
CCS has an example file for the 16F877 to wake up from sleep by using
the #int_ext interrupt:
Quote: |
c:\program files\picc\examples\ex_wakup.c |
znses
Posted: Tue May 10, 2011 12:47 pm |
I got this error message A #DEVICE required before this line
when I want to use the example code
If I want to use a bush button of RB4 in ICD3 how can I manage that ?
#if defined(__PCM__)
#include <16F877.h>
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7) // Jumpers: 8 to 11, 7 to 12 to 12
// global flag to send processor into sleep mode
short sleep_mode;
// external interrupt when button pushed and released
#INT_EXT
void ext_isr() {
static short button_pressed=FALSE;
if(!button_pressed) // if button action and was not pressed
button_pressed=TRUE; // the button is now down
sleep_mode=TRUE; // activate sleep
printf("The processor is now sleeping.\r\n");
ext_int_edge(L_TO_H); // change so interrupts on release
else // if button action and was pressed
button_pressed=FALSE; // the button is now up
sleep_mode=FALSE; // reset sleep flag
ext_int_edge(H_TO_L); // change so interrupts on press
if(!input(PIN_B0)) // keep button action sychronized wth button flag
delay_ms(100); // debounce button
// main program that increments counter every second unless sleeping
long counter;
sleep_mode=FALSE; // init sleep flag
ext_int_edge(H_TO_L); // init interrupt triggering for button press
enable_interrupts(INT_EXT);// turn on interrupts
printf("\n\n");
counter=0; // reset the counter
if(sleep_mode) // if sleep flag set
sleep(); // make processor sleep
printf("The count value is: %5ld \r\n",counter);
counter++; // display count value and increment
delay_ms(1000); // every second
Posted: Tue May 10, 2011 1:03 pm |
Quote: | I got this error message A #DEVICE required before this line |
It means you don't have the PCM compiler installed, or you don't have
the 16F877 selected in MPLAB, or in the CCS IDE. You've got to learn
how to use the compiler before you do a project.
Quote: | when I want to use the example code
If I want to use a push button of RB4 in ICD3 how can I manage that ? |
The ICD3 programmer doesn't affect anything about using RB4 as an
interrupt. It's completely an unrelated topic. To use RB4, you would
have to use the #int_rb interrupt. But in the 16F877, this interrupt works
for pins B4-B7 all at the same time. You can't enable it for just one pin.
At your level of knowledge, this is too difficult. I suggest you use pin B0
with #int_ext. The #int_ext interrupt only uses Pin B0, and is much
easier for you to do. |
znses
Posted: Tue May 10, 2011 1:22 pm |
Regarding the error : Error 128 "C:\Users\kustaff\Desktop\bunage\T.c" Line 4(1,70): A #DEVICE required before this line
I ensured that all your step for detecting this error are confirmed but I still get this error despite I have been programming other codes and it worked !
Regards |
Posted: Tue May 10, 2011 1:28 pm |
It compiles OK for me. I copy-and-pasted it into an existing project for
the 16F877 in MPLAB (I commented out the other code for that project)
and it compiled without errors.
If I change the PIC in MPLAB menu for "Configure / Select Device" to
something else like 18F452, then I get the same error as you.
So, I still say that your configuration is probably incorrect.
What is your compiler version ? |
