using ADC to determine low battery ?
M11
PostPosted: Sat May 07, 2011 3:02 pm     Reply with quote
I want to detect the battery voltage and give a signal when it falls bellow a certain value. I know how to do this using a comparator, but is it possible to do it using the ADC of the PIC16f877 ?
note: the battery is the power source of the PIC.
thanks is advance
PostPosted: Sat May 07, 2011 4:06 pm     Reply with quote
Very easy.
Use a voltage divider to reduce the battery max to 5 volts.
Read the ADC, compare the reading to a lookup table of 'Ok, low, dead battery voltages.
Display on LCD or send to PC.
Done.
M11
PostPosted: Sat May 07, 2011 4:23 pm     Reply with quote
but doesn't the reference voltage of the ADC changes when the voltage of the battery changes ?
PostPosted: Sat May 07, 2011 4:56 pm     Reply with quote
Read these previous threads on the topic:
How to design low battery indicator?
http://www.ccsinfo.com/forum/viewtopic.php?t=24560
How to monitor battery level that is running the PIC itself?
http://www.ccsinfo.com/forum/viewtopic.php?t=27096
Low Voltage Detect interrupt
http://www.ccsinfo.com/forum/viewtopic.php?t=24577
newbee - battery level
http://www.ccsinfo.com/forum/viewtopic.php?t=23186
Checking battery voltage with A/D
http://www.ccsinfo.com/forum/viewtopic.php?t=24842
