Int32 comparison problem
calvin
PostPosted: Fri May 06, 2011 12:43 am     Reply with quote
Hi!
I have a the following code:
int32 AA,BB;
AA=-4;
if(AA > 0){
  // do some thing 1
BB=0:
if(AA > BB){
  // do some thing 2
Allways the code executes "do some thing 1" and "do some thing 2".
Why??
Thanks for your help
calvin
Another case:
PostPosted: Fri May 06, 2011 1:01 am     Reply with quote
For more illustration:
          if(-2 < -4){
            EVENTO(196);
          if(-2 > -4){
            EVENTO(197);
CCS generates the following .lst
....................           if(-2 < -4){
....................             EVENTO(196);
....................           if(-2 > -4){
....................             EVENTO(197);
2156:  MOVLW  C5
2158:  MOVWF  x9C
215A:  MOVLB  0
215C:  CALL   0CE6
why???
FvM
PostPosted: Fri May 06, 2011 1:47 am     Reply with quote
With 8 Bit CCS compilers, int defaults to unsigned (unless overridden by a #TYPE statement).
So all negative constants are interpreted as positive values, the result is correct.
calvin
PostPosted: Fri May 06, 2011 7:02 am     Reply with quote
Thanks FvM I will read about that.But, is fine too that the compile doesnt generate code for some statements? that is not for signed or unsigned data types.
SherpaDoug
PostPosted: Fri May 06, 2011 8:27 am     Reply with quote
If the compiler can tell at compile time that certain code can never be reached, it will not generate machine code for those statements. They are optimized out of existence.
FvM
PostPosted: Fri May 06, 2011 8:36 am     Reply with quote
Sure. Conditional code after a constant compare that evaluates to false will be removed.
calvin
PostPosted: Fri May 06, 2011 11:54 am     Reply with quote
Thanks to all for your help.
