UnLiMiTeD!!!
How to use two ADC inputs? [Solved] |
Posted: Wed May 04, 2011 7:49 am |
I have problem about using two different adc inputs. I dont know how to sepret it, i need to read value from one input, and after that from other one. But with this code: Code: | int a,b;
setup_adc_ports(ALL_ANALOG);
setup_spi(SPI_SS_DISABLED);
setup_timer_1(T1_DISABLED);
// TODO: USER CODE!!
set_adc_channel(2);
a = read_adc();
set_adc_channel(3);
b = read_adc();
output_b(a);
output_c(b);
I have problem what two values comes together.
It will be great if anyone can help.
thanks |
UnLiMiTeD!!!
Posted: Wed May 04, 2011 7:57 am |
I solve the problem, its need just to put delay here is the code Code: | #use delay(clock=4000000)
int a,b;
set_adc_channel(2);
delay_us(20);
a = read_adc();
set_adc_channel(3);
delay_us(20);
b = read_adc();
output_b(a);
output_c(b);
