PIC18F2550 internal oscillator[SOLVED]
teknoman
PostPosted: Mon May 02, 2011 12:41 am     Reply with quote
CCS compiler:4.121
I want to use internal oscillator. Recently I use command INTRC_IO and everything works fine.
But now compiler not accept that. I can't find right command in header file?
What I have to do? Is that some bug??
OLD header file:
#device PIC18F2550
#nolist
//////// Program memory: 16384x16  Data RAM: 2048  Stack: 31
//////// I/O: 23   Analog Pins: 10
//////// Data EEPROM: 256
//////// C Scratch area: 00   ID Location: 200000
//////// Fuses: XT,XTPLL,EC_IO,EC,ECPIO,ECPLL,INTRC_IO,INTRC,PROTECT
//////// Fuses: NOPROTECT,BROWNOUT_NOSL,BROWNOUT_SW,NOBROWNOUT,BROWNOUT,WDT1
//////// Fuses: WDT2,WDT4,WDT8,WDT16,WDT32,WDT64,WDT128,WDT,NOWDT,BORV20
//////// Fuses: BORV28,BORV43,BORV46,PUT,NOPUT,CPD,NOCPD,NOSTVREN,STVREN
//////// Fuses: NODEBUG,DEBUG,NOLVP,LVP,WRT,NOWRT,WRTD,NOWRTD,IESO,NOIESO
//////// Fuses: FCMEN,NOFCMEN,PBADEN,NOPBADEN,CCP2B3,CCP2C1,WRTC,NOWRTC,WRTB
//////// Fuses: NOWRTB,EBTR,NOEBTR,EBTRB,NOEBTRB,CPB,NOCPB,MCLR,NOMCLR
//////// Fuses: LPT1OSC,NOLPT1OSC,XINST,WDT256,WDT512,WDT1024,WDT2048
//////// Fuses: WDT4096,WDT8192,WDT16384,WDT32768,NOXINST,INTXT,INTHS,HS
//////// Fuses: HSPLL,PLL1,PLL2,PLL3,PLL4,PLL5,PLL6,PLL10,PLL12,CPUDIV1
//////// Fuses: CPUDIV2,CPUDIV3,CPUDIV4,USBDIV,NOUSBDIV,VREGEN,NOVREGEN
NEW header file:
//////// I/O: 23   Analog Pins: 13
//////// Fuses: PLL1,PLL2,PLL3,PLL4,PLL5,PLL6,PLL10,PLL12,CPUDIV1,CPUDIV2
//////// Fuses: CPUDIV3,CPUDIV4,NOUSBDIV,USBDIV,XT,XTPLL,EC_IO,EC,ECPLL_IO
//////// Fuses: ECPLL,INTEC_IO,INTEC,INTXT,INTHS,HS,HSPLL,NOFCMEN,FCMEN
//////// Fuses: NOIESO,IESO,PUT,NOPUT,NOBROWNOUT,BROWNOUT_SW,BROWNOUT_NOSL
//////// Fuses: BROWNOUT,BORV45,BORV43,BORV27,BORV20,NOVREGEN,VREGEN,NOWDT
//////// Fuses: WDT,WDT1,WDT2,WDT4,WDT8,WDT16,WDT32,WDT64,WDT128,WDT256
//////// Fuses: WDT512,WDT1024,WDT2048,WDT4096,WDT8192,WDT16384,WDT32768
//////// Fuses: CCP2B3,CCP2C1,NOPBADEN,PBADEN,NOLPT1OSC,LPT1OSC,NOMCLR,MCLR
//////// Fuses: NOSTVREN,STVREN,NOLVP,LVP,NOXINST,XINST,DEBUG,NODEBUG
//////// Fuses: PROTECT,NOPROTECT,CPB,NOCPB,CPD,NOCPD,WRT,NOWRT,WRTC,NOWRTC
//////// Fuses: WRTB,NOWRTB,WRTD,NOWRTD,EBTR,NOEBTR,EBTRB,NOEBTRB
PostPosted: Mon May 02, 2011 12:53 am     Reply with quote
See this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=45169
teknoman
PostPosted: Mon May 02, 2011 5:20 am     Reply with quote
ThankĀ“s for helping
