newpic
how to get PWM 40khz out |
Posted: Fri Apr 29, 2011 1:34 pm |
I use timer2, try to get 40khz out to drive an ultrasonic sensor.
Can anybody help?
Code: | #include <16f877.h>
#fuses XT, NOWDT, NOPROTECT, NOBROWNOUT, NOPUT, NOLVP
output_low(PIN_C1); // Set CCP2 output low
setup_ccp2(CCP_PWM); // Configure CCP2 as a PWM
setup_timer_2(T2_DIV_BY_16, 124, 1); // 500 Hz
set_pwm2_duty(31); // 50% duty cycle on pin C1
Code: | setup_timer_2(T2_DIV_BY_16, 124, 1); // 500 Hz |
what do I need to set here to get 40khz out? Explaination will helpful. |
newpic
40khz pwm to drive ultrasonic |
Posted: Fri Apr 29, 2011 2:15 pm |
I got it. here is the new code
setup_timer_2(T2_DIV_BY_1, 24, 1); // 40kHz
Crystal Frequency
PWM Freq = -----------------------------------------
(PR2 + 1) * (Timer2 Prescaler) * 4
** I need 40000 (40khz), so I need a number that 4000000 / x = 40000
so x is 100. I need to get a number (a+1)*4 = 100
a = is 24; which is (24+1)*4 = 100.
* to get duty cycle, .25 * 24 = 6,
set_pwm2_duty(6); // 25% duty cycle on pin C1
