#int_RDA not working
cbkulatunge
PostPosted: Thu Apr 28, 2011 3:20 am     Reply with quote
I'm receiving serial data from external loadcell amplifier via usart.
it works fine without external int. rda clash when i enable #int_ext
working code
processor;
#include <18F452.h>
#fuses hs,nowdt,noprotect,brownout,noput
#use delay(clock=20M)
main;
void main(){
   initz();
   kbd_init();
   output_high(alarm);
   output_low(w_ok);
   default_display();
   while(true){
      disable_interrupts(int_rda);
      display_weight();
      enable_interrupts(int_rda);
interrupt;
#int_EXT
void  EXT_isr(void)
   output_low(h_open);
   output_low(h_close);
#int_RDA
void RDA_isr(void){
   rxda=getc();
   if(rxda!='g'){
      rxdbuf[r_count]=rxda;
      r_count++;
   }else{
      r_count=0;
      weight=0;
      multiplier=1;
      for(s=18;s>0;s--){
         if((rxdbuf[s]>47)&(rxdbuf[s]<58)){
            weight+=(rxdbuf[s]-48)*multiplier;
            multiplier*=10;
      output_high(pin_d0);
above code work fine until this
#int_EXT
void  EXT_isr(void)
   output_low(h_open);
error occur in any function calls
please help!
PostPosted: Thu Apr 28, 2011 5:01 am     Reply with quote
Rule number one. Code inside ISRs MUST be short
Rule Number two. NEVER use delay_ms() in any ISR.See rule number one!
Rule Number three. ALWAYS add 'errors' to the use rs232() dirrective.
That's 3 ideas from me..others can help point out other code flaws..
cbkulatunge
PostPosted: Thu Apr 28, 2011 9:30 am     Reply with quote
thanx for reply bro.
i'v already tried with 'errors' directive with rs232 which no effect on this matter. i couldn't find any way to shorten the code inside isr
rnielsen
PostPosted: Thu Apr 28, 2011 10:40 am     Reply with quote
for(s=18;s>0;s--){
multiplier*=10;
Put this code in your main() and simply set a flag in the ISR and evaluate that flag in main to do that for() loop. This for() is just as bad as a delay() and will cause you problems. The for() loop could be taking up too much time and you could miss a character coming in.
Ronald
pic_micro
PostPosted: Thu Apr 28, 2011 10:53 am     Reply with quote
I think you miss the enable_interrupts(GLOBAL);
cbkulatunge
PostPosted: Thu Apr 28, 2011 8:24 pm     Reply with quote
void initz(){
   //ports
   output_a(0);
      setup_adc_ports(NO_ANALOGS);
      setup_adc(ADC_OFF);
   PORT_b_PULLUPS(true);
   set_tris_e(0);
   bit_set(trisb,0);
   bit_set(trisb,1);
   bit_set(trisb,2);
   bit_clear(trisb,3);
   bit_clear(trisc,5);
   EXT_INT_EDGE(0,h_to_l);
   EXT_INT_EDGE(1,h_to_l);
   EXT_INT_EDGE(2,h_to_l);
   enable_interrupts(global);
cbkulatunge
PostPosted: Thu Apr 28, 2011 8:33 pm     Reply with quote
@rnielsen
i thought so. but conversion must be continues. original main function more complex than i posted. i do few calculations and comparison using 'weight' variable.
this is a one of my function within main()
void fill_high(){
   int32 closepoint,limit1_point,limit2_point,add_w,sub_w;
   int limit1_factor,lastbit;
   lastbit=read_eeprom(0x2E);
   read_setpoint();
   add_w=get_eeprom(0x25,2);
   sub_w=get_eeprom(0x27,2);
   limit1_factor=read_eeprom(0x2c);
   limit2_point=get_eeprom(0x29,2);
   if(limit1_factor>99){limit1_factor=10;}
   closepoint=(setpoint + add_w) - sub_w;
   limit2_point=closepoint-limit2_point;
   limit1_point=(int32) ((limit1_factor * limit2_point)/100.);
   get_delays();
   dir=0;
   output_high(h_open);
   delay_ms(hodl);
   output_low(h_open);
   enable_interrupts(int_ext1);
   enable_interrupts(int_ext2);
   dir=1;
   do{
   }while(weight<limit1_point);
   output_high(h_close);
   do{
   }while(weight<limit2_point);
   output_low(h_open);
   lastpoint=1;
   do{
   }while(weight<closepoint-lastbit);
   delay_ms(afcd);
   if(weight<closepoint){
      delay_ms(afod);
      output_low(h_open);
      delay_ms(afcd);
   lastpoint=0;
   disable_interrupts(int_ext1);
   disable_interrupts(int_ext2);
   display_weight();
   output_high(w_ok);
   output_high(buzer);
   delay_ms(400);
   output_low(buzer);
   delay_ms(400);
   output_high(buzer);
   delay_ms(400);
   output_low(buzer);
