Broken Output port Pin?
hello188
PostPosted: Tue Apr 26, 2011 8:08 pm     Reply with quote
Hi, currently, I am working with PIC18Fk46k22, and checking the output functionality.
To PORTD0~PORTD.5, a solenoid relay is connected via opto-coupler with separate ground, so the MCU is electrically isolated from the back EMF from inductor.
To check, I simply set port direction to outputs and output 0x00 to the PORTD, to turn on the LED and solenoid.
I am working with two identically constructed target board, and looking at PORTD register with ICD3 debugger.
The strange thing I discovered is that depending on the target board, WITH SAME PROGRAM, certain bits(higher bits, which are 7, 6, 5,4) can not stay 0, and instead gets pulled back up to 1.
Below is my code
//SETUP
#INCLUDE<18F46K22.h>
#INCLUDE<def_18f46K22.h>
#FUSES HSH, NOPLLEN, NOIESO, PUT, NOBROWNOUT, NOWDT, NOPBADEN, MCLR, STVREN
void main(void){
TRISD  = 0x00;
PORTD = 0x00
As I look at the registers on the WATCH window, TRISD remains 0x00 but PORTD reads 0b00010000 or 0b00110000 depending on the target board.
I am thinking the two pins(PORTD.5, and PORTD.6) got somehow damaged? I think that the condition is affecting the SFRs too since ICD3 is reading from them.
Anyone has experienced this??
Thank you
PostPosted: Tue Apr 26, 2011 8:40 pm     Reply with quote
Post your compiler version.
hello188
PostPosted: Tue Apr 26, 2011 9:51 pm     Reply with quote
It's 4.120 The latest
When I run it with simulator instead of ICD3, the port behaves fine.
Thank you
PostPosted: Tue Apr 26, 2011 10:35 pm     Reply with quote
What do you see if you look at the pins with an oscilloscope ?
Also, describe your oscillator circuit.
FvM
PostPosted: Wed Apr 27, 2011 12:39 am     Reply with quote
What's the IO load current? Source or sink?
hello188
PostPosted: Wed Apr 27, 2011 5:19 pm     Reply with quote
On the oscilloscope, the voltage is Vcc.
The sink currents should be less than 10 mAs
