multiple instances of built-in functions with PCD?
billpa
PostPosted: Tue Apr 26, 2011 11:42 am     Reply with quote
I need to do 32 bit integer multiplies and divides at both interrupt and task time with PCD. But, I can’t have global interrupts disabled at task time in the MULS3232 and DIVS3232A functions generated by the compiler.
Is it possible to tell the compiler to create another instance of these two functions? Or, anybody have 32 bit integer mul/div source available? Smile
Thanks!
Bill
Bill
PostPosted: Tue Apr 26, 2011 12:02 pm     Reply with quote
See this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=42118
billpa
PostPosted: Tue Apr 26, 2011 12:27 pm     Reply with quote
THANK YOU!!!
Bill
PostPosted: Tue Apr 26, 2011 2:49 pm     Reply with quote
Seriously though, try to work out a way of avoiding the divides!....
Remember that /2,/4 etc., can be done using a shift. It is often possible to scale numbers 'up', using a multiply, and then use one of these. Difference in time is really major. Worth thinking very carefully if you can about this....
