problem with the setup_spi() function
bright
PostPosted: Sun Apr 24, 2011 11:12 am     Reply with quote
I understand that if you want to use spi in ccs, you have to first setup the spi by this line of code : setup_spi( SPI_MASTER | SPI_H_TO_L | SPI_CLK_DIV_16), now I understand the SPI_MASTER parameter, what I do not understand is the SPI_H_TO_L parameter, oh and also for the third parameter if you want to use the full oscillator frequency what should you write? Sad
PostPosted: Sun Apr 24, 2011 11:48 am     Reply with quote
It's much easier if you use SPI modes instead of CCS's constants.
The following define statements allow you to select any SPI mode.
// SPI mode definitions for 16F and 18F PICs.
#define SPI_MODE_0  (SPI_L_TO_H | SPI_XMIT_L_TO_H)
#define SPI_MODE_1  (SPI_L_TO_H)
#define SPI_MODE_2  (SPI_H_TO_L)
#define SPI_MODE_3  (SPI_H_TO_L | SPI_XMIT_L_TO_H)
This post has an example of how to do it:
http://www.ccsinfo.com/forum/viewtopic.php?t=45258&start=3
This page has a good diagram of the 4 modes:
http://elm-chan.org/docs/spi_e.html
You need to look at the timing diagram for your SPI slave device and
decide what mode it uses. The two things to look for are:
1. The idle state of SCLK (high or low). Look at the sides of the timing
diagram to see the idle state, before and after the SPI transaction.
2. The clock edge of SCLK (rising or falling) that is used to sample the
SPI data. Look at the edge of SCLK that occurs in the middle of a data
bit. Notice if it's rising or falling. Here is another quick reference to
help you decide what mode the slave is using:
http://www.totalphase.com/support/kb/10045/#modes
You also need to select an i/o pin on your SPI Master PIC for the
Chip Select signal. Example:
#define SPI_CS  PIN_C2
There is no option to use the direct PIC oscillator frequency for SCLK.
The smallest divisor is 4. So if you have a 40 MHz oscillator, you can
get a 10 MHz SCLK.
