I need pic 18f452 long delay time code. We need one hour delay time code input port b /output port d . controller continue while _________________ Seamax Enterprise Engineering Services
1 hour delay is super easy.
Create simple ISR with 1 second heartbeat aka software RTC.
Set a flag if 1 hour, again aka software RTC
Code is given in the code library..and it works !
nazim
long time delay code
Posted: Sun Apr 24, 2011 9:36 am
I have tried to make the long time delay code but it did not worked.
portd output delay 1 hour 18f452 but while continue _________________ Seamax Enterprise Engineering Services
SherpaDoug
Posted: Sun Apr 24, 2011 11:44 am
Can you show us the code you tried and tell us what it seemed to do? Also telling us the version of your compiler often helps. _________________ The search for better is endless. Instead simply find very good and get the job done.
