RFID with ID20, need help
Goto page 1, 2, 3  Next
motts
PostPosted: Sun Apr 17, 2011 3:53 pm     Reply with quote
hi, I am new for RFID, Can any help me for the coding to read the tag ID by the reader ID20(125khz) and show in LCD by using micro controller 18F4550? I have try a lot of way but still cant get ... pls help me.... thk for helping. god bless
PostPosted: Sun Apr 17, 2011 5:27 pm     Reply with quote
Make Google your friend. There are several examples with code on using that ID20 module. Might take you a couple days to find what you need but cheaper than paying me for 2 hours of my time to cut custom code for you!
motts
PostPosted: Sun Apr 17, 2011 7:58 pm     Reply with quote
THK for , your reply ...
Delfy_Coltech
First step,
PostPosted: Sun Apr 17, 2011 8:26 pm     Reply with quote
Good morning,
Firstly, you have to design the schematic. How to connect ID20 to PIC?
Which pin of ID20 that use to receive tag ID's data?
Then, post your schematic here.
Many people can help you!
Mechatronics Department, Coltech, VNUH
Hanoi, Vietnam.
f0raster0
look..
PostPosted: Tue Apr 19, 2011 12:28 pm     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?p=139806#139806
motts
PostPosted: Thu Apr 21, 2011 6:34 am     Reply with quote
Thk for helping.
the RFID Reader ID 20 connection in here
http://www.sparkfun.com/datasheets/Sensors/ID-12-Datasheet.pdf
The pin of ID 20 will connect to PIC18F4550 Pin 26 (Port c7 RX).
Then I want the tag code show in LCD.
I am sorry that I not really know how to show my schematic on here, so only can use to describe here....
which can get help from you all ... thk you very much.
f0raster0
PostPosted: Thu Apr 21, 2011 10:03 am     Reply with quote
http://imageshack.us/
this web.. you must register and you can store images..
for example,
http://img515.imageshack.us/i/ttlars232.jpg/
this is ID-20 to RS232
motts
PostPosted: Thu Apr 21, 2011 11:19 am     Reply with quote
thk for helping .... this is my diagram.
Wish can get help from you guy ... thk you all ...
http://img641.imageshack.us/img641/1742/id20.png
http://img39.imageshack.us/img39/7061/schpic.png
This is what i did, i can read the code but, this code won't loop. I mean after i scan 1 tag, it no longer can show the second ID.
What i need project is about payment system. Where by RFID to replace the barcode. After scan the tags the system can accumulate the total price also.... can anyone give some idea or coding ?
Really thk you all very much..
motts
PostPosted: Thu Apr 21, 2011 11:20 am     Reply with quote
#include <18f4550.h>
#fuses HS,NOLVP,NOWDT,NOPROTECT
#use delay(clock=20000000)         // 40 MHz crystal on PCB
#use rs232(baud=9600, UART1)      // hardware UART; uses  RC6/TX and RC7/RX
#define use_portb_lcd TRUE
#include <lcd.c>
int16 i;
char value[12];//12 values of tag ID
void main() {
   output_low(PIN_D7); //Set enable to low
   do
     for (i=0; i<12; i++) { //read in the 12 values
              value[i]=getc();
     if(value[1]=='0' && value[2]=='C' && value[3]=='0' && value[4]=='0' && value[5]=='2' && value[6]=='7' && value[8]=='8' && value[5]=='5' && value[9]=='6' && value[10]=='D'){
     printf("ID = 0C0027856D,Apple\r\n");
     lcd_putc("\fID = 0C0027856D");
     lcd_putc("\nItem = Apple");
     }if(value[1]=='1' && value[2]=='2' && value[3]=='0' && value[4]=='0' && value[5]=='C' && value[6]=='2' && value[7]=='7' && value[8]=='C' && value[9]=='1' && value[10]=='C'){
     printf("ID = 1200C27C1C,Orange\r\n");
     lcd_putc("\fID = 1200C27C1C");
     lcd_putc("\nItem = Orange");
     }if(value[1]=='1' && value[2]=='2' && value[3]=='0' && value[4]=='0' && value[5]=='C' && value[6]=='2' && value[7]=='8' && value[8]=='8' && value[9]=='F' && value[10]=='3'){
     printf("ID = 1200C288F3,Grape\r\n");
     lcd_putc("\fID = 1200C288F3");
     lcd_putc("\nItem = Grape");
     }if(value[1]=='1' && value[2]=='2' && value[3]=='0' && value[4]=='0' && value[5]=='C' && value[6]=='2' && value[7]=='8' && value[8]=='F' && value[9]=='0' && value[10]=='3'){
     printf("ID = 1200C28F03,Peach\r\n");
     lcd_putc("\fID = 1200C28F03");
     lcd_putc("\nItem = Peach");
     }if(value[1]=='0' && value[2]=='D' && value[3]=='0' && value[4]=='0' && value[5]=='6' && value[6]=='A' && value[7]=='C' && value[8]=='8' && value[9]=='F' && value[10]=='6'){
     printf("ID = 0D006AC8F6,Pear\r\n");
     lcd_putc("\fID = 0D006AC8F6");
     lcd_putc("\nItem = Pear");
     }if(value[1]=='0' && value[2]=='D' && value[3]=='0' && value[4]=='0' && value[5]=='6' && value[6]=='A' && value[7]=='A' && value[8]=='9' && value[9]=='3' && value[10]=='D'){
     printf("ID = 0D006AA93D,Apricot\r\n");
     lcd_putc("\fID = 0D006AA93D ");
     lcd_putc("\nItem = Apricot");
   }while(TRUE);
f0raster0
PostPosted: Thu Apr 21, 2011 12:08 pm     Reply with quote
this is bad..
this true
#use delay(clock=20000000) // 20 MHz crystal on PCB
"What I need project is about payment system. Where by RFID to replace the barcode. After scan the tags the system can accumulate the total price also."
price¡¡ in supermarket??
I place ID-20 and PC with software, for example VBasic mm or similar, but not PIC.
The tag RFID for product is expensive, and barcode is still cheap supermarket.
motts
PostPosted: Thu Apr 21, 2011 1:06 pm     Reply with quote
The frequency is wrong typing.
Ya, I know, the bar code still is the cheaper. My project just want to show how successful the RFID can be done.
Thk for your helping.
Anyone still got any idea to do it?? Please leave your idea and coding.
Thk you all very much.
f0raster0
PostPosted: Thu Apr 21, 2011 1:27 pm     Reply with quote
ok.. I say, this is my idea
ID-20 --> RS232--> PC or
ID-20 --> RS232--> Converter RS232-USB --> PC
in PC, I can help using Visual Basic 6.0, you know some software, mm C++ or php, etc..?
motts
PostPosted: Thu Apr 21, 2011 1:57 pm     Reply with quote
My programming very bad .... don't know how to use those visual basic.
If using pc to show tag id and with the accumulation pricing, also can for my project. Cause I just want to show the result.
motts
PostPosted: Thu Apr 21, 2011 2:01 pm     Reply with quote
If you not mind, you can add my msn, for easy to chat.
personal86@hotmail.com
Your help, I really appreciate it. Thk you very much.
f0raster0
PostPosted: Thu Apr 21, 2011 3:10 pm     Reply with quote
what is your plan?
ID-20 --> PIC --> LCD
or
ID-20 --> PC --> Software?
Page 1 of 3
