ex_bootloader.c for 16F883?
cerr
PostPosted: Thu Mar 24, 2011 1:15 pm     Reply with quote
Hi There,
I created a new project in MPLAB and added ex_bootloader.c to it, I changed the two top includes to <16F883.h> and hit F10 to compile - and what I got is:
*** Error 71 "ex_bootloader.c" Line 82(0,1): Out of ROM, A segment or the program is too large real_load_program
Seg 0004A-001FF, 016A left, need 01C1
Does this mean this bootloader is not working with this mcu?
Thanks,
Ron
PS: Using 4.119
cerr
PostPosted: Thu Mar 24, 2011 3:36 pm     Reply with quote
I've figured out that the problem seems to be
#define LOADER_END   0x1FF
in bootloader.h - tried different values with looking at the memory map of the datasheet but haven't figured out a way to get it working yet :( Any one able to assist?
Thank you,
Ron
cerr
PostPosted: Fri Mar 25, 2011 3:03 pm     Reply with quote
User Zilym from the Microchip forum posted an archive containing his version of a 16F883 bootloader which I used and worked fine. The link to the thread for future reference: http://www.microchip.com/forums/m347843.aspx Very Happy
cerr
PostPosted: Fri Apr 15, 2011 2:59 pm     Reply with quote
Hi There,
I am back at this as I really would like to use a CCS implementation of a bootloader on my F883 but I cannot get it compiled... Sad
Any suggestions to get rid of the Out of ROM, A segment or the program is too large real_load_program
error? :(
PostPosted: Sat Apr 16, 2011 5:22 am     Reply with quote
If it's because your program is too big(trying to suff size 12 feet into size 8 shoes ) ,you'll have to reduce it...
If it's overall small enough to fit..
You've got to rewrite your entire program to fit into the pages of memory
If a chunk of code is bigger than a page, you'll have to split it up into smaller parts.
Press F11( onscreen help) to look in the FAQ section.... or search here for possible solutions.
Things to consider, using 'common' functions or macros,use integer math,etc.
It's a common 'problem',easily fixed by 'tightening' up the code,old school stuff when entire programs were assembled into 1KB or less.
cerr
PostPosted: Sat Apr 16, 2011 12:38 pm     Reply with quote
Yes, I know and do understand this, but what I'm looking at here is the example bootloader that comes with CCS... does it seems to be incompatible with this mcu, or what? Sad
PostPosted: Tue Apr 19, 2011 5:47 pm     Reply with quote
I've created a technique to solve the problem of how to get
Ex_bootloader.c to compile for a different PIC.
The first thing to do is to compile Ex_bootloader.c for the default 16F877
and then draw a memory map of all the program segments.
The .SYM file lists all the program segments and their address in ROM.
I have re-arranged them below, to put them in the correct address order:
ROM Allocation:
0004  isr
0020  MAIN
0020  @cinit
0040  load_program
004A  atoi_b16
0082  real_load_program
0170  @@WRITE_PROGRAM_MEMORY
0200  application
I only have the PCM (and PCH) compilers. If you have PCWH, etc., then
you get the .STA file which has more information, such as the size of each
segment and how many bytes are used in each one. But I don't need it.
The next step is to create the memory map, with the #org and #define
statements that control the starting address and size of each segment.
This is for the 16F877, for compiler vs. 4.119.
0x0000
Reset Vector
0x0004
isr()
#org 0x20, 0x3F
main()
@cinit()
#define LOADER_END  0x1FF   // In Bootloader.h
#define LOADER_SIZE 0x1BF   // In Bootloader.h
//      0x40          0x1FF        0x1BF
#define LOADER_ADDR  (LOADER_END - LOADER_SIZE)
//   0x40,        0x49
#org LOADER_ADDR, LOADER_ADDR +9
load_program()
//   0x4A,            0x1FF
#org LOADER_ADDR +10, LOADER_END
atoi_b16()
real_load_program()
@@write_program_memory()
//   0x200,         0x209
#org LOADER_END +1, LOADER_END +10
application()
Now we can edit Ex_bootloader.c and change the #include line for the
PIC to your desired PIC, the 16F883. When I compile it, I get this error:
Out of ROM, A segment or the program is too large: real_load_program
The ROM space required by real_load_program() for the 16F883 is
larger than the 16F877. Why would this be ? Look at real_load_program()
in the Loader.c file. Notice the #if-#endif statements.
If they are executed, additional ROM space will be required. To see if
this is the case, I'm going to add a #warning message at the start of
the #if block, and re-compile:
#if getenv("FLASH_ERASE_SIZE") > getenv("FLASH_WRITE_SIZE")
#warning Flash erase size is greater than the write size
When I compile for the 16F883, I get the warning. When I compile for
the 16F877, I don't get it. So that's one reason why the code is larger.
The #if block is being executed for the 16F883.
Another reason is because the @@write_program_memory() routine is
much larger for the 16F883 than for the 16F877. The code for the
16F883 is 68 ROM words larger. If you comment out the #nolist line
at the start of the 16F883.h (or 16F877.h) file and re-compile, you will
see the ASM code for @@write_program_memory().
Another common reason for differences in code size is the start-up code
@cinit in main(). It's larger for the 16F883 by 13 ROM words.
To fix the problem we need to increase the ROM segment size for
real_load_program. This is controlled by LOADER_END and LOADER_SIZE.
They are both defined at the start of the Bootloader.h file
The compiler error message tells us that it needs 0x57 more ROM words.
This is from 0x1C1 - 0x16A = 0x57. Let's round it up to 0x60.
Now let's edit the file and add 0x60 to each of the default values in
Bootloader.h, so the modified code looks like this:
#if defined(__PCM__)
   #define LOADER_END   (0x1FF + 0x60)
   #define LOADER_SIZE  (0x1BF + 0x60)
We re-compile, and it gets rid of the real_load_program() error, but now
we have a new error. The main() segment is too small by 9 ROM words:
Out of ROM, A segment or the program is too large: MAIN
Seg 00020-0003F, 0020 left, need 0029
This means the solution is more complex. We need to change the #org
statement for main() to increase the size of its segment, and also move
up the starting address of the real_load_program() segment.
Here's the solution:
Edit Ex_bootloader.c and increase the #org segment for main() by 0x10
as shown below in bold:
#if defined(__PCH__)
#org 0x40,0x7F
#else
#org 0x20, 0x3F + 0x10 // For the PCM compiler
void main(void) {
if(!input(PIN_B5))
load_program();
application();
Now edit Bootloader.h and add 0x10 to LOADER_END. This will shift the
starting point for that block upwards by 0x10 bytes. This allows room for
the increased size of the main() segment that we did above. This change
is shown below in bold:
#define LOADER_END (0x1FF + 0x60 + 0x10)
Finally after doing all this, it compiles with no errors.
I tested it in hardware. I don't have a 16F883, but I do have a 16F887
and it's in the same PIC family. It required the same changes to the
code as given above. I followed the bootloader procedure that is listed
in this post and it worked:
http://www.ccsinfo.com/forum/viewtopic.php?t=40920&start=1
Here's what it displayed on the terminal. It's working.
Application program version 1.00
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20
21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37
38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54
55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71
72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88
89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104
105 106 107 108 109 110 111 112 113 114 115 116 117
and so on.
cerr
PostPosted: Wed Apr 20, 2011 10:04 am     Reply with quote
NICE work PCM. Awesome description of how I can solve the problem! Thanks so much, this is super appreciated. In the meantime I got a bootloader with microchip AN1310 to work successfully but I sure wanna go through the ccs version and apply your changes too!
Your efforts are much appreciated!
Thanks bud!
SubhamayS
ex_bootloader.c modification for PIC18F4520
PostPosted: Sat Dec 20, 2014 1:35 am     Reply with quote
Is it possible to configure 'ex_bootloader.c' for PIC18F4520 ? I am using CCS PCH C Compiler, Version 5.015 and the default 'ex_bootloader.c' is configured with 18F45K22. I have changed the header file and replaced it with 18F4520.h. I have also changed the crystal value to 20MHz (from default value 16MHz) the code is compiling successfully without any error. I proceeded further and verified the output of 'ex_bootloader.c' at the TeraTerm V4.73. I kept PIN_A4 connected to Ground. then pressed the reset button. I got the desired output at the terminal window, which was showing -
"Bootloader Version 1.0
Waiting for download..."
Then I compiled the 'ex_bootload.c' and successfully downloaded the .HEX file in my PIC18F4520.
Now as I reset the PIC I am suppose to see the output of 'ex_bootload.c', but nothing is being displayed in the terminal window except some garbage values.
Is it a problem with the crystal oscillator ? Should I keep it with default value 16MHz ? Please help !!! Sad
PostPosted: Sat Dec 20, 2014 1:38 am     Reply with quote
Did you change the clock statement in ex_bootload to match your crystal?.
The fuses and clock statements need to be the same in both bootloader _and_ bootloaded program.
SubhamayS
PostPosted: Mon Dec 22, 2014 7:55 am     Reply with quote
Thanks a lot for the reply.
yes I have checked the crystal and it is 20Mhz for both bootloader _and_ bootloaded program.
while debugging I have added some output_high() in order to drive LEDs to trace the flow of program execution.
void main(void) {
   if(!input(PUSH_BUTTON))
      printf("\r\nBootloader Version 1.0\r\n");
      // Let the user know it is ready to accept a download
      printf("\r\nWaiting for download...");
      output_high(PIN_B4); //red LED
      load_program();
      output_high(PIN_B3); //blue LED
   application();
Now after burning this modified 'ex_bootloader.c', when the reset button is pressed it shows the desired message in TeraTerm & the RED led glows. and then after downloading the 'ex_bootload.c', the Blue LED is not glowing. So, is it that there may be a problem in the execution of the function load_program();. I have compared the .SYM files for Both 18F45K22 (default device) & 18F4520 which is given below.
ROM Allocation: 18F45K22 (Default Device)
000008 isr
00001E @const724.call
00003A @const726.call
000054 @PSTRINGC_9600_31766_31767
000076 @PUTCHARI_BIU_1
00007E atoi_b16
0000E4 @FLASHWR
000104 @WRITE_PROGRAM_MEMORY
000148 real_load_program
00031A load_program
000320 MAIN
000320 @cinit1
000354 @cinit2
000500 application
ROM Allocation: PIC18F4520
000008 isr
00001E @const674.call
00003A @const676.call
00007E atoi_b16
0000E4 @FLASHWR
000158 real_load_program
0003E8 load_program
0003EE MAIN
0003EE @cinit1
000414 @cinit2
000500 application
Is it a problem due to differences in code size ? @WRITE_PROGRAM_MEMORY is taking more space in 18F4520 than the default device. Do I need to increase the ROM segment size for @WRITE_PROGRAM_MEMORY & others following !! Rolling Eyes
PostPosted: Mon Dec 22, 2014 11:46 pm     Reply with quote
I tested it just now with vs. 5.015, and an 18F4520, with a 16 MHz crystal
and it worked OK. It displayed incrementing numbers on Teraterm:
Application Version 1.0
37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82
83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103
104 105 106 107 108 109 110 111 112 113 114 115
I then removed the 16 MHz crystal and installed a 20 MHz crystal.
I edited both files, ex_bootloader.c and ex_bootload.c, and changed the
#use delay() to 20 MHz in each one. I then re-compiled both projects
and programmed ex_bootloader.hex into the 18F4520 with a Pickit 3.
Then I did the normal bootload procedure and it worked.
Your problem sounds like what Ttelmah said. Maybe you forgot to
re-compile the Ex_bootload project after you edited the Ex_bootload.c file.
If you forgot to re-compile it, then it would still be expecting the hardware
to have a 16 MHz crystal and it would produce garbage output on a board
running at 20 MHz.
SubhamayS
PostPosted: Tue Dec 23, 2014 8:42 am     Reply with quote
running at 20 MHz.
Thanks for the reply. I have double checked each step pointed by you but the same problem prevails. The oscillator configuration is alright.
But as I am dowloading the 'ex_bootload.hex' through TeraTerm... after completion of download. the same message is being displayed again:
This I think, is due to the fact that a restart of the program is occurring. and the application(); function is never being called. I think in my case the program somehow is getting stuck at the call of load_program();.
If possible could you please provide me the code of 'ex_bootloader.c' you are using for PIC18F4520.
PostPosted: Tue Dec 23, 2014 10:24 am     Reply with quote
I'm not going to post it. If you have vs. 5.015, then you have the same
code.
Are you sure you're doing the download process correctly ? This post
describes how to do it. Except, CCS changed it to use pin A4 (not pin B5).
You have to make sure that TeraTerm has XON/OFF enabled in the
Setup / Serial Port / Flow Control menu.
