I have searched and not found any info on this. I think the TCP/IP stack from CCS is 3.75 and this module uses 5.25... Will CCS have a driver and stack for this? Any thoughts. Thanks
Is it an option to just compile the stack with c18 and use ccs for the rest of the project ? Sorry if thats a dumb question.
Will Reeve
Joined: 30 Oct 2003 Posts: 209 Location: Norfolk, England
Posted: Mon Apr 18, 2011 9:32 am
I am neck deep in this exact same problem. Bought C18 for the job as well. If CCS would like to port the latest stack that would be great!
Will Reeve
Posted: Tue May 10, 2011 7:13 am
C18 is not that bad, bit of a learning curve and you have to stop using all the nice tricks built into the CCS complier. It's working perfecting for my WiFi application...will I move to C18. Probably not. I like the simpler CCS way of doing things! If you need a hand drop me a PM.
anlpereira
Re: microchip MRF24WB0MA WiFi module?
Posted: Tue Sep 24, 2013 2:11 pm
Hi, have you find the CCS stack for this modules yet? Can you send it to me?
