pierokun
interfacing between PIC18F and Transceiver CC1101 |
Posted: Mon Apr 18, 2011 4:06 am |
hi everyone,
I need some help with my study project at University. I have to make interface between Microcontroller PIC18F and Transceiver CC1101, using CCS compiler C.
Now, I found a lot of datasheet about CC1101, some examples of sources code with other PIC or MCU, but i'm very blocked because of SPI interface.
Someone can help me please?! If I can't initialize SPI Pins, I couldn't communicate with CC1101.
I tried that :
#use spi(BAUD=9600,MASTER, DI=PIN_C4, DO=PIN_C5, CLK=PIN_C3, BITS=8, MSB_FIRST, MODE=0, ENABLE=PIN_A3) |
and my definition of Pins is :
Code: | #define SCK PIN_C3 // is connected to SCLK of CC1101 <--> RC3/SCK/SCL of PIC18F
#define MISO PIN_C4 // is connected to SO of CC1101 <--> RC4/SDI/SDA of PIC18F
#define MOSI PIN_C5 // is connected to SI of CC1101 <--> RC5/SDO of PIC18F
#define CSn PIN_A3 // is connected to CSn of CC1101 <--> RA3 of PIC18F
I saw that some people use this:
setup_spi(SPI_MASTER | SPI_L_TO_H | SPI_CLK_DIV_4 ); |
But don't know if it is good.
I'm really SAD. I try to visualize signal SCK or SO on oscilloscope, but nothing appears.
Please help........ :(
My thanks in advance. |
Joined: 01 Jul 2010 Posts: 9174 Location: Greensville,Ontario
Posted: Mon Apr 18, 2011 5:03 am |
CCS kindly supplies a few examples in the examples folder, which is a good place to start!
Your code of ...use spi(baud=9600...) is NOT how SPI is configured!
While SPI is a serial form a of communication, it's speed is not setup using baud=nnnn.
Again several examples of SPI are provided by CCS.
SPI is a very simple serial interface and the CCS functions make using it easy.
You should 'google', CCS C code and CC1101 to see if there are any 'hits'. Unless you're the very first one using the two, there's probably a few hundred or thousands of hits! |
