AJEFenConsultancy
PIC 16F1827 not running |
Posted: Thu Apr 14, 2011 7:07 am |
I am working on a project using a PIC 16F1827, using it's internal oscillator
running at 8MHz. I can download firmware into the micro and verify that the code
has successfully been programmed. However the code does not appear to be
running. I have verified this by writing code to toggle a pin and have viewed
this pin on an oscilloscope. I have pasted my code below. Could someone
enlighten me as to what I may be doing wrong.
I am using the CCS PCM C compiler from MPLAB 8.63.
Thanks in advance
Andrew Ellis
// main.c
// Set up the processor
#include <16F1827.h>
#fuses INTRC_IO,PLL,PUT,BROWNOUT,NOMCLR
#fuses NOIESO,NOFCMEN,NOCLKOUT,NOLVP,NODEBUG,BORV25,NOSTVREN
#use delay(clock=8000000)
setup_oscillator(OSC_8MHZ | OSC_INTRC | OSC_PLL_ON);
// Setup port B; 0 - output, 1 - input
set_tris_b(0xC6);
while (1)
output_bit(PIN_B3, ~input(PIN_B3));
_________________ Kind regards
Andrew Ellis |
AJEFenConsultancy
Posted: Thu Apr 14, 2011 7:09 am |
I forgot to add that I haves ensured that /MCLR is pulled high with a 1k resistor. _________________ Kind regards
Andrew Ellis |
gaugeguy
Posted: Thu Apr 14, 2011 8:03 am |
B3 is an analog pin by default, so it will always read as a 1 and the output will always be a 0. You need to disable all analog modules associated with this pin to use it as a digitial I/O. |
Wayne_
Posted: Thu Apr 14, 2011 8:08 am |
also
output_toggle(PIN_B3);
should work just as well
And set_tris should not be required in this situation. |
AJEFenConsultancy
Posted: Thu Apr 14, 2011 10:46 am |
Hi guys,
thank you very much for your replies.
Unfortunately I'm no further forward.
My code now reads:
// main.c
SETUP_ADC_PORTS(NO_ANALOGS);
while (1)
Interestingly if I run the code through the debugger it works fine, and I can observe pin B3 toggling. Is there a subtle option I have missed?
Regards
Andrew _________________ Kind regards
Andrew Ellis |
Posted: Thu Apr 14, 2011 11:48 am |
Quote: | I am using the CCS PCM C compiler from MPLAB 8.63. |
That's the MPLAB version. What's the compiler version ?
It's given at the top of the .LST file, which will be in your project directory
after a successful compilation. Example of compiler version numbers:
http://www.ccsinfo.com/devices.php?page=versioninfo |
jeremiah
Posted: Thu Apr 14, 2011 11:50 am |
try putting a delay in your loop with the toggle statement:
for example:
while (1)
Posted: Thu Apr 14, 2011 6:14 pm |
Did you set the 'build configuration' to 'release' from 'debug' then recompile (F10) BEFORE burning the PIC ? |
AJEFenConsultancy
Posted: Fri Apr 15, 2011 3:14 am |
Thank you for your replies.
The version of the compiler I'm using is 4.108.
I have tried changing the build from "Debug" to "Release", but that hasn't helped, I have also tried putting a delay in my loop, but these didn't work.
I have added the line:
#fuse CLKOUT
and observed pin 15 with a scope, but there is no clock pulse on that pin.
Does anyone have any further ideas please.
Andrew Ellis |
Posted: Fri Apr 15, 2011 4:30 am |
Start by 'stepping back'. Since you are working 'through' MPLAB, start with the basic program:
#device adc=8
#FUSES NOWDT, INTRC_IO, PUT, NOPROTECT, NOMCLR, NOCPD, BROWNOUT, IESO, FCMEN,
#FUSES CLKOUT, NOWRT, NOVCAP, STVREN, BORV25, NODEBUG, NOLVP, RESERVED
setup_adc_ports(NO_ANALOGS);
setup_spi(FALSE);
setup_vref(FALSE);
do {
delay_ms(1);
} while(TRUE);
Now some comments about the changes here:
CLKOUT, to give a test output - good idea.
You cannot have clock=8MHz, and PLL_EN. If you enable the PLL, your clock becomes 32MHz.
You always want STRVEN. If the stack overflows, the code _will_ crash. STRVEN, at least gives some chance of recovery....
Compile this.
Then go into the 'Configure', 'Configuration bits' window, and verify that the tick box 'Configuration bits set in code' is made. Then look at how the fuses _are_ set. They should show:
INTOSC oscillator, I/O function on RA7/OSC1/CLKI
WDT disabled
PWRT enabled
RA5/MCLR/Vpp pin function is digital input
Program memory code protection is disabled
Data memory code protection is disabled
Brown-out Reset enabled
CLKOUT function is enabled on RA6/CLKOUT pin
Internal/External switchover mode is disabled
Fail-safe Clock Monitor is disabled
Write protection off
4x PLL disabled
Stack overflow or underflow will cause a reset
Brown-out Reset Voltage (VBOR) sert to 2.7v
High voltage on MCLR/VPP must be used for programming.
Now, if these are _not_ set like this, then this is the heart of your problem. Turn off the 'set in code' tick box, and correct them.
Now I have compiled this with your compiler version, and the fuses are set correctly, and the chip merrily gives a 500Hz output on B3.
AJEFenConsultancy
Posted: Fri Apr 15, 2011 7:42 am |
Hi Ttelmah,
Thank you for your help.
My code is up and running now
Andrew Ellis |
