Stupid question :lol:
Eddy71ua
PostPosted: Thu Apr 14, 2011 8:15 am     Reply with quote
Several times in the listings I saw a record number: 5000000L What does the letter L after the number 5000000?
frequency =  (5000000L / (float)current_ccp_delta);
I reread the instruction to the compiler and have not found an answer to this simple question.
newguy
PostPosted: Thu Apr 14, 2011 8:44 am     Reply with quote
Long. It forces the compiler to use 16 or 32 bit manipulations. ....Kind of like a forced cast I suppose.
Eddy71ua
PostPosted: Thu Apr 14, 2011 12:43 pm     Reply with quote
Of course is long. 5000000 does not fit in int16. Why is it tells the compiler?
PostPosted: Thu Apr 14, 2011 3:00 pm     Reply with quote
Probably 'left in'.
Key is that if the same function is used with different numbers - perhaps 'defines', and the numbers drop below first 65536, and then below 256, the compiler will switch to using first 16bit, and then 8bit arithmetic. Using 'L' prevents this. It is part of standard C, and 'belt and braces', quite good practice if you want to be absolutely _sure_ that a drop back won't happen.
Eddy71ua
PostPosted: Thu Apr 14, 2011 3:02 pm     Reply with quote
Thank you very much for the detailed response Rolling Eyes
