interrupts in DSPic and timers [SOLVED]
on7nh
View user's profile Send private message Visit poster's website MSN Messenger
PostPosted: Sun Apr 10, 2011 1:38 pm     Reply with quote
i have some strange problems,
when i set timer2 to internal, all interrupts stops working...no more timers ect...
any sugestions ?
Carl
#include <30f4013.h>
#device adc=12
#FUSES WDT // Watch Dog Timer
#FUSES HS
#FUSES NOCKSFSM //Clock Switching is disabled, fail Safe clock monitor is disabled
#fuses HS2_pll8 // div by 3 and  multiply the ext. clock of 40mhz by 8x
#define XTAL_FREQUENCY 120000000,RESTART_WDT
#use delay(clock=XTAL_FREQUENCY)
#use rs232(stream = RS232, baud=115200,parity=N,uart2,bits=8)
//#use i2c(Master, SDA=PIN_F2, SCL=PIN_F3, FORCE_HW, slow)
#use fast_IO(b)
#int_ext0 level=7
#int_ext1 level=7
#int_ext0 fast
#int_ext1 fast
/////////////////// Variabelen /////////////////
   long      EL_actu_position,AZ_actu_position;
   long       EL_calc_position,AZ_calc_position;
   long       EL_dest_position,AZ_dest_position;
   int         EL_init_ok, AZ_init_ok;
   long      EL_offset, AZ_Offset,AZ_u1;
   int         EL_stapteller=0,AZ_stapteller;
/////////////////// UIT-gangan /////////////////
      #define AZ_enc_A      PIN_A11   // input    pen 17
      #define AZ_enc_B      PIN_B4   // input   pen 6
      #define AZ_enc_Z      PIN_B11   // input   pen 36
      #define EL_enc_A      PIN_D8   // input    pen 23
      #define EL_enc_B      PIN_B5   // input    pen 7
      #define EL_enc_Z      PIN_B12   // input    pen 35
      #define AZ_Enbl_Drive   PIN_F1   // output    pen 29
      #define EL_Enbl_Drive   PIN_F0   // output    pen 30
      #define AZ_pwm_CCW      PIN_D3   // output    pen 19
      #define AZ_pwm_CW      PIN_D2   // output    pen 22
      #define EL_pwm_CCW      PIN_D1   // output    pen 33
      #define EL_pwm_CW      PIN_D0   // output    pen 34
      void RS232();
/****************** encoder Azimuth inlezen *******************/
   #int_ext0
   void EXT_Encoder_AZ()
      if (input(AZ_enc_B) == 1)
               AZ_actu_position = AZ_actu_position + 1;
               AZ_actu_position = AZ_actu_position - 1;
/****************** encoder elevatie inlezen *******************/
   #int_ext1
   void EXT_Encoder_EL()
      if (input(EL_enc_B) == 1)
               EL_actu_position = EL_actu_position +1;
               EL_actu_position = EL_actu_position- 1;
   #INT_TIMER1
   void TIMER1_isr()
        rs232();
   void rs232()
         printf("%c[2J%c[H",27,27);
         printf("ff$apel,%d*\r\n",EL_actu_position);
         printf("dd$apaz,%d*\r\n",AZ_actu_position);
         printf("$dpel,%u*\r\n",EL_dest_position);
         printf("$dpaz,%u*\r\n",AZ_dest_position);
         printf("$lsel%u,%u*\r\n",input(EL_CW_Lswitsh),input(EL_CCW_Lswitsh));
         printf("$lsaz%u,%u*\r\n",input(AZ_CW_Lswitsh),input(AZ_CCW_Lswitsh));
         printf("Fout            AZ    %d\n\r",AZ_u0);
         printf("Speed +-500      AZ   %d\n\r",AZ_u1);
         printf("Fout         EL   %d\n\r",EL_u0);
         printf("Speed +-500      EL   %d\n\r",EL_u1);
         printf("Stapteller    AZ  EL    %d  %d\n\r",AZ_actu_position,AZ_calc_position);
Void main()
   set_tris_b(0b0001100100111111);
//   setup_timer2(TMR_INTERNAL | TMR_DIV_BY_8,5000);   // prescale=64, PR2=255
   setup_timer1(TMR_INTERNAL | TMR_DIV_BY_256,65000);   // prescale=64, PR2=255 roept seriele communicatie aan
   //// initialisatie PWM's ///////////////
//   setup_compare(1, COMPARE_PWM | COMPARE_TIMER2);      // Configre for PWM mode
//   setup_compare(2, COMPARE_PWM | COMPARE_TIMER2);      // Configre for PWM mode
//   setup_compare(3, COMPARE_PWM | COMPARE_TIMER2);      // Configre for PWM mode
//   setup_compare(4, COMPARE_PWM | COMPARE_TIMER2);      // Configre for PWM mode
   AZ_PWM(0,0);
   EL_PWM(0,0);
   //// initialisatie Interrupts ///////////////
   EXT_INT_EDGE(L_TO_H);
   enable_interrupts(INT_timer1);
   enable_interrupts(INT_timer2);
   enable_interrupts(INT_EXT1);
   enable_interrupts(INT_EXT0);
//   enable_interrupts(intr_GLOBAL);
   While(1)
         if ((AZ_init_ok != 1))//||(EL_init_ok != 1))
                  if (AZ_init_ok != 1)
                     Init_AZ(); //   eerst initialisatie uitvoeren
            ///////   de regellus doorlopen
      restart_wdt();//at least one in the main while(1) loop
   }//end while(1)
}//end void main()
on7nh
PostPosted: Sun May 15, 2011 12:12 pm     Reply with quote
problem solved.....
when i use PWM...never enable the selected timer...
