Getting "Option invalid No Internal Osc" when co
c_user
PostPosted: Fri Apr 08, 2011 3:57 pm     Reply with quote
I have a design I previously compiled a long time ago. I just downloaded the latest version of the compiler and now come up with a bizarre message.
I am using a pic18F4550 device, with an internal oscillator. In spite of this, the compiler complains with:
*** Error 99 "ccs.c" Line 3(5,28): Option invalid No Internal Osc
The test code is simply:
#include <18f4550.h>
#use delay(internal = 4MHz)
   setup_oscillator(OSC_4MHZ|OSC_INTRC|OSC_31250|OSC_PLL_OFF);
The complaining line is:
Any thoughts?
PostPosted: Fri Apr 08, 2011 4:26 pm     Reply with quote
I was able to make it work with the internal oscillator in vs. 4.119 with
the following settings. CCS has changed the names of the oscillator
fuses to match the 18F4550 data sheet. So "INTHS" means to use the
internal oscillator for the PIC, and the HS oscillator (with crystal) for the
USB module.
#include <18F4550.h>
#fuses INTHS, NOWDT, BROWNOUT, PUT, NOLVP
#use delay(clock=4M)
setup_oscillator(OSC_INTRC | OSC_4MHZ);
// Blink LED once per second.
   output_toggle(PIN_B0);
c_user
PostPosted: Fri Apr 08, 2011 5:08 pm     Reply with quote
Thank you for helping.
