PIC16F1824 Optimization error
Pekub
PostPosted: Mon Apr 04, 2011 3:13 am     Reply with quote
Compiler: 4.119
I made a little larger program on PIC16F1824.
I use two struct
struct TG
   short ItWasErr;
   int8 NoSignalErrCnt;
   int8 LostSignalErrCnt;
   int8 Filter;
    int16 LastAvg;
   int8 nnNextSpeed;
   int16 SpeedBuff[16];
} Tg1, Tg2;
and I use interrupt from Timer2
void MyFunc(struct TG *ptg)
#int_timer2
void timer2_isr()
   setup_timer_2(T2_DIV_BY_16,249,10);    // 1.0 ms overflow
   Led_On();
In main() function I call MyFunc(&Tg1);
There are more problems:
1. Program jumps to interrupt routine and then resets
2. Function restart_cause returns 0x3F / this is not defined in file 16F1824.h /
What it means ?
3. When I use optimization level 0, program works fine.
4. When I define and use pointer to struct
struct TG *ptg;
ptg = &Tg1;
and then I call MyFunc(ptg)
the program works fine.
5. When I reduced size of program, the program works fine.
My program is too big to send it.
Where is the problem ? In compiler or in optimization or in my code ?
Please help me.
Thank's
Peter
PostPosted: Mon Apr 04, 2011 11:43 am     Reply with quote
It's difficult to help you without a test program.
My suggestion is to use one or more of your work-arounds and
continue with the project.
Wayne_
PostPosted: Tue Apr 05, 2011 1:57 am     Reply with quote
As PCM programmer states, it is almost impossible to help you without a test program but saying that I would say your problem is in the LED_On function ;)
I expect it is doing something it shouldn't. but without seeing what it does I have no idea.
Pekub
PostPosted: Tue Apr 05, 2011 5:17 am     Reply with quote
I am maximally simplify my program and all functions. The program now does not perform any function, but the problem remained.
The processor will be reset about every 2 sec.
#case
#include <16F1824.h>
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES NOWDT                      //Watch Dog Timer
#FUSES NOPUT                      //Power Up Timer
#FUSES NOBROWNOUT                 //Brownout reset
#FUSES BORV25                   //Brownout reset at 2.5V
#use delay(clock=16000000)
#use FAST_IO(A)
#use FAST_IO(C)
int8 RxBuff[32];        // when I remove this line, program works o.k.
#define IN_TG1       PIN_A4   // vstup upraveneho signalu z TG1
#define IN_TEST      PIN_C2   // vstup - tlacidlo "Test"          povodne PIN_A2
#define LED_TEST     PIN_C4   // LED LD3 "Test"
#define TG_SPEED_BUFF_SIZE 16
struct TG
   short IsSignal;                  // priznak signalu z TG
   short IsBlocking;                // priznak blokovania z TG
   short NoSignalErr;               // priznak chyby TG - "Nie je signal"
   short LostSignalWarning;         // priznak chyby TG - Varovanie "Mozna strata signalu"
   short LostSignalErr;             // priznak chyby TG - "Strata signalu"
   short ItWasErr;                  // priznak chyby TG - "Uz bola chyba"
   int8 NoSignalErrCnt;             // citac poruchoveho stavu "TG - Nie je signal"
   int8 LostSignalErrCnt;           // citac poruchoveho stavu "TG - Strata signalu"
   int8 Filter;                     // hodnota pre digitalne filtrovanie
   int16 SpeedCnt;                  // citac pre urcenie rychlosti z TG
   int16 ActualSpeed;               // aktualna hodnota rychlosti z TG
   int16 AvgSpeed;                  // priemerna hodnota rychlosti z TG
   int16 LastAvg;                   // predosla priemerna rychlost z TG1 / pred podozrenim na stratu signalu /
   int8 nnNextSpeed;                // index pre buffer SpeedBuff pre nasledujucu hodnotu
   int16 SpeedBuff[TG_SPEED_BUFF_SIZE];   // buffer rychlosti
} Tg1, Tg2;
//struct TG *ptg1 = &Tg1;        // when I enable this line, program works o.k.
struct FILTERED_INPUT
   short FiIn;
   short RiEdge;
   short FaEdge;
   short Finish;
   int8 LowCnt;
   int8 HighCnt;
struct FILTERED_INPUT InTest, InRst, InTg1, InTg2;
// definicie makier
#define Led_TEST_On() (output_high(LED_TEST))    // zapnutie LED TEST
#define Led_TEST_Off() (output_low(LED_TEST))    // vypnutie LED TEST
#inline
void FIN_Read(struct FILTERED_INPUT *fio, short pinIn, int8 sampleCnt)
// pocet citani pinu = SampleCnt + 1
   if(fio->Finish == FALSE)
      fio->FiIn = pinIn;
   if(pinIn == 0)
      fio->HighCnt = 0;                // nuluje citac "1-urovne"
#int_timer4
void timer4_isr()
   setup_timer_4(T4_DIV_BY_4,9,10);       //10.0 us overflow, 100.0 us interrupt
   FIN_Read(&InTg1, input(IN_TG1), Tg1.Filter);  // nacita vstup z TG1
void TG_Obsluha(struct TG *tg)
#zero_ram
   // inicializacia
   setup_oscillator(OSC_16MHZ|OSC_INTRC|OSC_PLL_OFF,0);
   setup_adc_ports(ADC_OFF);
   set_tris_a(0b11111010);       // A0,A2=output, A1,A3-A5=input
   set_tris_c(0b00000100);       // C0,C1,C3-C5=output, C2=input
   Led_TEST_On();
   delay_ms(150);
   Led_TEST_Off();
   enable_interrupts(INT_TIMER4);
      FIN_Read(&InTest, input(IN_TEST), 30);    // when I remove this line, program works o.k.
      TG_Obsluha(&Tg1);                         // when I remove this line, program works o.k.
      //TG_Obsluha(ptg1);
PostPosted: Wed Apr 06, 2011 1:43 pm     Reply with quote
Does this program run correctly if you use "#opt 0" ?
Pekub
PostPosted: Thu Apr 07, 2011 4:56 am     Reply with quote
I identified it is not optimization error.
The program does not work with #opt 0 and even with #opt 9 - default value.
I still do not know what is wrong.
I'm going to change my application to another processor PIC18F14K22 and will wait for a new version of the compiler.
