Serial Port monitor, taking wrong characters
Grkan13
PostPosted: Wed Apr 06, 2011 9:01 am     Reply with quote
I'm trying to send some simple printf commands, but there is something wrong about settings i think.
here is my code:
#include <16F877.h>
#device adc=8
#FUSES xt
#FUSES PROTECT                  //Code protected from reads
   printf("Hello World, please");
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_timer_1(T1_DISABLED);
I see on the screen " Nenno>Wornf, *neyse"
When i try to send " battery" i saw rottery and it was changing. sometime "bottery" and sometimes "battery"
PostPosted: Wed Apr 06, 2011 9:34 am     Reply with quote
Have you got a good earth connection?.
What is generating you processor clock.
Grkan13
PostPosted: Wed Apr 06, 2011 9:43 am     Reply with quote
i'm using http://www.alldatasheet.net/datasheet-pdf/pdf/35051/POWER-ONE/MAP55-4001.html for power connection and its grounding.
I tried 20Mhz and 4Mhz crystals but result didn't change
PostPosted: Wed Apr 06, 2011 10:01 am     Reply with quote
What is the PCB layout round the crystals, what loading capacitance are they meant to have, what capacitors were you using?. Your link gives no details of how you are linking the serial ground, which is what 'matters' for the communication.
Your fault is classic for a connection not having both wires for the connection (the data line and the ground), properly connected, or the USART clock is unreliable.
Also what are you using for the level translation on the connection?.
Grkan13
PostPosted: Wed Apr 06, 2011 10:57 am     Reply with quote
I'm using a breadboard. My capacitors for the crystals are 22pf ceramic.
There are 5 pins on the power connector, +5V, GND, +24V, -12V, +12V. I've just connected the +5V and +12V to the my breadboard with a cable.
Hmm I think the problem is not connecting properly on the rs-232 connector, I will try to change it. Because when I order they send me wrong connector, I have a female without pins. Male connector's pins and my data and ground cables are just touching each other in holes.
