code memory problem
bells_electronics
code memory problem
PostPosted: Mon Apr 04, 2011 11:58 am     Reply with quote
hey guys
i am using pic16F877A, i am gettting 2-16bits variables data via RS232 now my task is to store these variables data permanently in my PIC,
how i can do that does any one has a source code for it ??
PostPosted: Mon Apr 04, 2011 1:11 pm     Reply with quote
This CCS driver file has routines to read and write 'int16' values to
internal data eeprom inside the PIC.
c:\program files\picc\drivers\internal_eeprom.c
bells_electronics
PostPosted: Mon Apr 04, 2011 1:38 pm     Reply with quote
sir
i am lil confuse here what address should i use ?? hex or decimal ??
address = 0;
address = 1
for 2 16-bit variables ??
PostPosted: Mon Apr 04, 2011 1:43 pm     Reply with quote
The address is a byte address. It starts at 0. There are two bytes per
word. So put your first int16 value at address 0, and put your next int16
value at address 2.
