PIC18F14K50 internal EEPROM
pebbert9
PostPosted: Fri Apr 01, 2011 2:41 pm     Reply with quote
I am trying to write to the internal EEPROM of the PIC18F14K50
I run the following code and it seems to read and write, but when I comment out the write operation and just do the read, it's not reading the data that was previously written.
Is there a fuse I'm missing?
#include <18F14K50.h>
#fuses HS,NOWDT,NOLVP,MCLR,PUT,NODEBUG,BROWNOUT,NOWRTD,NOCPD
#use delay(crystal=12000000)
#use rs232(baud=9600, UART1, errors)
   char value;
   write_eeprom (1, '$');
   value = read_eeprom (1);
   printf("\r\nData: %c", value);
   while (TRUE)  {
PostPosted: Fri Apr 01, 2011 2:46 pm     Reply with quote
Your programming software is probably erasing the eeprom. Look in the
setup window for your programmer (i.e., MPLAB, etc.) and tell it to
preserve the eeprom.
pebbert9
PostPosted: Fri Apr 01, 2011 3:05 pm     Reply with quote
Thank you, I had to disable it in CCSLOAD.
