"typedef struct" is not a pointer?
cerr
PostPosted: Wed Mar 30, 2011 5:03 pm     Reply with quote
Why does this little sample app not compile? :o
#include <18F87K22.h>
#device HIGH_INTS=TRUE, adc=16, ICD=TRUE
#FUSES NOWDT                      //No Watch Dog Timer
#FUSES WDT128                     //Watch Dog Timer uses 1:128 Postscale
#FUSES HSM                        //Hi-Speed crystal oscillator
#FUSES NOBROWNOUT                 //No brownout reset
#FUSES NOPLLEN                    //No PLL enabled
#FUSES BBSIZ1K                    //1K words Boot Block size
#FUSES NOXINST                    //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
typedef struct {
   int16 var1;
   int16 var2;
   int16 var3;
}MyStruct;
MyStruct TestMe;
MyFunc(MyStruct *Foo);
void main (void)
   TestMe.var1=1;
   TestMe.var2=2;
   TestMe.var3=3;
   MyFunc(TestMe);
   Foo->var1=Foo->var2+Foo->var3;
PostPosted: Wed Mar 30, 2011 5:55 pm     Reply with quote
void main (void)
TestMe.var1=1;
TestMe.var2=2;
TestMe.var3=3;
MyFunc(TestMe);
Edit the line in bold to pass the address of the structure.
cerr
PostPosted: Wed Mar 30, 2011 5:59 pm     Reply with quote
Uhm yes, but I'm confused, why isn't TestMe itself a pointer to the first element comparable to an array? Shocked
PostPosted: Wed Mar 30, 2011 7:29 pm     Reply with quote
In this Wikipedia article, they get the address of the my_point structure
by putting an & in front of it:
&my_point;
Link to Wikipedia article on Pointers to Structures
To show that this behavior is not confined to CCS, I made your program
into an MSVC++ 6.0 program (a C program). It gives me these messages:
error C2115: 'function' : incompatible types
warning C4024: 'MyFunc' : different types for formal and actual parameter 1
Both of those messages are about this line:
 MyFunc(TestMe);
If I change it to this:
 MyFunc(&TestMe);
Then it loves it:
Compiling...
Test.c
Linking...
Test.exe - 0 error(s), 0 warning(s)
Here is the MSVC++ 6.0 test program (This is a C file, not a C++ file):
// Test.c
#include <stdio.h>
#include <stdlib.h>
typedef struct {
   int var1;
   int var2;
   int var3;
}MyStruct;
MyStruct TestMe;
void main (void)
   TestMe.var1=1;
   TestMe.var2=2;
   TestMe.var3=3;
   MyFunc(TestMe);
   exit(0);
   Foo->var1 = Foo->var2+Foo->var3;
FvM
PostPosted: Wed Mar 30, 2011 11:37 pm     Reply with quote
Of course MyFunc(&TestMe); is the required syntax. TestMe represents the structure, not it's address.
You also can pass a structure as function parameter, if you want to.
The only case, where an object name can be used as a pointer is an array of characters, I think.
