PIC16f88 to lcd display
indep
PostPosted: Wed Mar 30, 2011 3:31 pm     Reply with quote
hello dear friends,
please someone help me, i am a newbie and stuck with my code from pic16f88 to display on 16x1 lcd. i wanted to display 0-5 volts with 3decimal places.. manythanks in advance!
PostPosted: Wed Mar 30, 2011 3:55 pm     Reply with quote
To help us help you, show us your code for the LCD. Have you got it to work with the classic 'hello World' program? 8 bit mode, 4 bit mode ?
WRT the ADC 8 bit mode, 10 bit mode, Vref a precision ref or just VDD?
I curently have an 88 here doing temp monitoring, display is a 16x2, 4 bit mode using the 'flexLCD' driver., works fine for me...
PostPosted: Wed Mar 30, 2011 3:57 pm     Reply with quote
16x1 Flex lcd driver:
http://www.ccsinfo.com/forum/viewtopic.php?t=30964
How to read analog voltage, convert to volts, and display on lcd:
http://www.ccsinfo.com/forum/viewtopic.php?t=32168
indep
PostPosted: Wed Mar 30, 2011 4:11 pm     Reply with quote
Thanks for the link PCM programmer i will have a look at that..
temtronic, code will be up shortly.. thanks
indep
PostPosted: Wed Mar 30, 2011 4:26 pm     Reply with quote
one question..
do i need to put the 16x1 flex driver before the lcd display code? thanks
PostPosted: Wed Mar 30, 2011 4:37 pm     Reply with quote
There are code examples in the links that I gave you. They show
exactly where to put the #include for the lcd driver.
indep
PostPosted: Thu Mar 31, 2011 4:40 pm     Reply with quote
Hi PCM programmer?..
can u send a link about transmitter and receiver please.. thanks..
also can u check if this flow of program is right or something is missing thank you..
voltage input-->pic16f88(A to D conversion, transmitter code)-->transmitter
receiver-->pic16f88(receiver code, digital value to voltage coversion, lcd driver, display code)-->lcd display..
many thanks
PostPosted: Thu Mar 31, 2011 4:53 pm     Reply with quote
Use Google to search the forum for this:
site:ccsinfo.com/forum rf link
This will also get many hits (for 433 MHz RF links):
site:ccsinfo.com/forum 433
I have not used any of these devices, so I can't help you with it.
