Flashing LED's
boogajamooga
Flashing LED's
PostPosted: Sun Mar 27, 2011 7:22 pm     Reply with quote
Hi, I am trying to implement this logic where the the PINs of the PIC16f877a will output high and turn on some LED's based on an if statement check. The If statement is comparing the analog input that I am inputting using a function generator. I am using a 5V peak to peak w/ offset 2.5v, so the lowest voltage ouputted from the function generator is 0v and the highest is 5v in a square wave function. This input is connected to pin RA0 of the PIC, which is an analog input port, and I am sending this input through the PIC's ADC, which I am setting up with the following code:
setup_adc_ports(ALL_ANALOG); //RA0 port is set to analog w/ Vcc as ref voltage to receive source tank sensor data
   setup_adc(ADC_CLOCK_DIV_32); //use the external 20mhz clock
   set_adc_channel(0); //sets it to read the analog value of the source tank at pin AN0
delay_ms(20); //allow some delay time in order for the PIC to set up the ADC after initializing the ports/clock
and this is my adc function that compares the analog input and returns a 0 if it is below the threshold, and a 1 if it above the threshold.
//Returns 0 if the current value is below the parameter theshold value. 1 otherwise
int ADC_threshold(int thresh){ //unsigned char makes it an 16-bit value, int makes the threshold variable a 16-bit value
   if(read_adc() < thresh) //compare the converted analog value to the middle value in hex between 0v and 5v
      return 0; //sets the variable to which it returns to a digital low
      return 1; //sets the variable to which it returns to a digital high
Next, in main, I am sending it through a while loop and then using an if statement where this adc function returns its result and outputting to the pins based on this. So, basically when the ADC determines that the analog input is below the threshold, it should output the pin to high, when it is below, it shoulnd't do anything, but the first time they go high, i never implemented code to turn the pins low so I am confused as to why they start to blink
int main(){
while(1){
if(ADC_threshold(THRESHOLD)){ //check to see if source tank is low.  if it is, don't even poll receiver channels and turn ALL motors off
            output_high(PIN_D2); //turn motor 0 off
            output_high(PIN_D3); //turn motor 1 off
            output_high(PIN_C4); //turn motor 2 off
            output_high(PIN_C5); //turn motor 3 off
            output_high(PIN_D4); //turn motor 4 off
            output_high(PIN_D5); //turn motor 5 off
            output_high(PIN_D6); //turn motor 6 off
            output_high(PIN_D7); //turn motor 7 off
} //end of while loop
      return 0;
}//end of main loop
Also, my function generator is cutting power to your output pins when the signal goes low. How would you fix that problem?
SherpaDoug
PostPosted: Mon Mar 28, 2011 5:51 am     Reply with quote
I assume you are powering the PIC from +5V? If it is 3V make sure the analog input never goes above the supply voltage.
Even at 5V I would still set the function generator to output 1V to 4V to start with just to make sure. It would also be good to put a 1000 Ohm resistor in the function generator output so weird stuff doesn't happen if the input pin gets set to an output.
demonspells
View user's profile Send private message Yahoo Messenger MSN Messenger
PostPosted: Mon Mar 28, 2011 12:53 pm     Reply with quote
your threshold is int, that means you should set the adc to 8bits
and the threshold should be between 0-255
to set the ADC to 8-Bits add this line to the beginning of your code
#DEVICE ADC=8
Badr Ghatasheh
