boogajamooga
output to port functions |
Posted: Thu Mar 24, 2011 8:51 am |
Hi, I am using compiler version 4.064 and I tested out these two functions and used LED's to test the following two commands: the CCS compiler built-in function: "output_high(PIN_D7); "
and the outputting it myself using: "output_d(0b10000000);"
I realize that you would also have to specify the address for the port D if you implement it my way so at the top of your code you'd have to say:
#byte port_d = 0x08
So what I wanted to know is, besides the one difference I mentioned above, does the built-in function that CCS provides do or set any other things in the PIC? basically what would be the exact difference between these two statements? I looked at the CCS compiler built-in functions manual and it doesn't seem to give any information on the actual code for how they implemented the built-in function.
Also, my implementation requires writing to the entire port everytime. So, I was wondering when using the built-in function, if you want to set a certain pin high for example, pin 3, does it write to ALL the pins in the port? so for example, would it do: 00000100? or does it put the value 1 in pin3 w/o writing to any of the other pins? Also, when using this in-built function, if you write to the same port sucessively, for example:
Code: | //case where you are below the middle threshold of tank
while(ADC_threshold(THRESHOLDMID) == 0 && Rising == 1){
output_high(PIN_D5); //turn on led 3 at pin RD5
output_low(PIN_C1); //disable transmitter
output_high(PIN_C2); //PortCBits2 = 1; disables sensor
In the code above, since I write to PINC1 and C2 which are on the same port C of the PIC, right after each other, sometimes I don't see them implemented correctly when I hook up LED's to the corresopnding pins to debug. Is this because when using the built-in function, does it take some time to write to the port? So should I include a delay between each write? For some reason when i do this:
delay_ms(500); //put in delay too allow time to write to pin
the code works fine, but I have some timing issues that cause problems when I put a delay in there. Is there anyway to make this work without having to use a delay? |
Posted: Thu Mar 24, 2011 9:31 am |
No, you don't need to have #byte port_d = 0x8.
The output_d instruction knows where port_d is.
Now. your problem sounds like RMW. A search here and generally regarding the PIC, for this will find a lot about it. When you set (or clear) one bit in a port on the PIC, the sequence _performed by the hardware_, is:
Read the current value on the port.
Set/reset the one bit requested.
Output this to the port.
Now, the problem appears if you have an output bit that is overloaded. If (for example), you turn on A0, and this is connected to a load that does not allow it to reach the voltage corresponding to a '1', then you set A1. When A0 is read, the chip sees the pin as being 'low' (since it is not at the high logic level), and clears it.....
Solutions:
First one is avoid overloading the pins. Now you talk about attaching LED's, what resistor value are you using to limit the current these draw?. Typically 270 or 330 ohms are needed. Otherwise the pins will be clamped to the LED Vf, and never go 'high'.....
Second, is when dealing with a _capacitive_ load, adding time delays. Here the pin may take a few uSec to actually reach the required level.
The 'RMW', stands for 'Read Modify Write', which is what the chip internally does when you set/reset one bit.
On later chips (18 family), the 'output register' is a separate register from the port itself, which avoids this problem if changing several pins quickly, with capacitive loads. However in the 'overloaded' version of the problem, if the chip is not to overheat, the hardware needs to be modified to avoid it.
boogajamooga
Posted: Thu Mar 24, 2011 12:34 pm |
wow thanks! the resistors were the problem. |
Joined: 01 Jul 2010 Posts: 9173 Location: Greensville,Ontario
Posted: Thu Mar 24, 2011 2:24 pm |
Also to see what CCS is doing for their functions, just print out the program.lst file. It'll give you all the information you need, probably more ! |
