		| Author | Message |
		| heUAcyp
				| setting up RTCC - PIC 18F24J11- timer -- please!! |
				|  Posted: Wed Mar 16, 2011 11:20 am |   |
				| Hi all,
 This is my first post on this forum, and I would be glad if anyone can answer my easy question.
 I am using PIC 18F24J11 , which has a real-time calendar clock embedded.
 I got the required 32.768 kHz Xtal connecting:
 PIN 11 (RC0/T1OSO/T1CKI/RP11) and
 PIN 12 (RC1/T1OSI/RP12) then each to ground with 12.5 pF capacitors.
 I need to keep track of real time in sleep mode using this external Xtal.
 I really need your help guyz, bcz could not figure out.
 Thanks in advance
		| PCM programmer
				|  Posted: Wed Mar 16, 2011 2:14 pm |   |
				| Always look in the Examples and/or the Drivers directory for sample code: Here is a CCS program for the internal RTC on the 18F26J11 series PICs:
  	  | Quote: |  	  | c:\program files\picc\examples\ex_rtcc.c
		| heUAcyp
				| rtcc.c |
				|  Posted: Wed Mar 23, 2011 12:10 pm |   |
				| Hi, thanks for the reply
 I do have ex_rtc.c , ex_rtclk.c , ex_rtctimer.c but not ex_rtcc.c .
 And I think they are not same. How can I find ex_rtcc.c ?
		| PCM programmer
				|  Posted: Wed Mar 23, 2011 12:12 pm |   |
				| You need a more recent version of the compiler. |  |
		| heUAcyp
				| PicKit_2 |
				|  Posted: Wed Mar 23, 2011 12:14 pm |   |
				| if I find ex_rtcc.c, I can still compile using PICkit 2 right? |  |
		| PCM programmer
				|  Posted: Wed Mar 23, 2011 12:35 pm |   |
				| PicKit 2 is a programmer, not a compiler. |  |
		| heUAcyp
				| ex_rtcc.c |
				|  Posted: Wed Mar 23, 2011 12:42 pm |   |
				| how can I find ex_rtcc.c file then boss? I really really do need that. |  |
		| PCM programmer
				|  Posted: Wed Mar 23, 2011 12:55 pm |   |
				| Get a more recent version of the compiler.   I can't help any more. |  |
		| heUAcyp
				|  Posted: Wed Mar 23, 2011 12:56 pm |   |
				| Thanks for your help |  |
		| heUAcyp
				| last question |
				|  Posted: Wed Mar 23, 2011 1:55 pm |   |
				| PCM may I ask a last question?
 What does ex_rtcc.c has and ex_rtc.c does not?
 thanks
		| PCM programmer
				|  Posted: Wed Mar 23, 2011 2:08 pm |   |
				| Ex_rtc.c is an example file that is used with the nju6355. driver file. The nju6355 is serial RTC chip.   This is the data sheet for it.
 http://www.qsl.net/df7tv/datasheets/nju6355ed.pdf
 This is not what you want, and it is useless for your project.
 Your PIC, the 18F24J11, has a built-in RTC section inside the PIC package.
 The file, Ex_rtcc.c, calls built-in functions in (some versions) of the CCS
 compiler that talk to the built-in RTC in the 18F24J11.   The RTC functions
 are described in the CCS compiler manual.   The Ex_rtcc.c program calls
 the following functions which talk to the RTC module:
  	  | Code: |  	  | setup_rtc();
 rtc_write();
 rtc_read();
 The CCS manual lists the following functions for the built-in RTC module
 in the 18F24J11.
  	  | Code: |  	  | REAL TIME CLOCK CALENDAR
 setup_rtc( )
 rtc_read( )
 rtc_write( )
 rtc_alarm_read( )
 rtc_alarm_write( )
 setup_rtc_alarm( )
 To use these functions, you must have a recent version of the compiler
 that supports them.  Also, CCS must have correctly written the functions
 and tested them, so they work in whatever version you are using.
		| heUAcyp
				|  Posted: Wed Mar 23, 2011 3:11 pm |   |
				| Thanks for the reply again!
 This is my code:
  	  | Code: |  	  | #include <18F24J11.h> #device ADC=10
 #include <STDIO.H>
 #include <stdlib.h>
 #include <math.h>
 #include <STRING.H>
 #fuses HS,NOWDT,NOPROTECT
 #use rs232 (baud=9600, xmit=PIN_C6, rcv=PIN_C7)
 time_t ti={0,0,0,0,0,0,0,0,0};
 setup_rtc(RTC_ENABLE,RTCC_INTERNAL);
 rtc_write(&ti);
 while(true)
 enable_interrupts(global);
 rtc_read(&ti);
 printf("%u\r\n",ti.tm_sec);
 I just want to see seconds incrementing on HyperTerminal but I cannot.
 Code is running , no errors - no warnings. How can I check if its working fine?
		| PCM programmer
				|  Posted: Wed Mar 23, 2011 3:32 pm |   |
				|  	  | Quote: |  	  | enable_interrupts(global); |
 Why are you enabling interrupts ?  You don't have an interrupt service
 routine.  What could interrupts possibly do, without that routine ?
 Also, what is your compiler version ?  Your version may not completly
 support the internal RTC.
		| heUAcyp
				| Compiler version |
				|  Posted: Wed Mar 23, 2011 3:46 pm |   |
				| Compiler version is V 4.087 , do I need a newer version? |  |
		| heUAcyp
				|  Posted: Wed Mar 30, 2011 1:33 pm |   |
				| PCM , As  suggested on previous topic, I now have compiler v 4.095.
 for the code I have posted above, I keep getting Error 54 : Expecting a variable.
 In the header file:
 I have:
  	  | Code: |  	  | typedef struct { int8 tm_year;
 int8 tm_yday;  // Not used by built in functions
 int8 tm_mday;
 int8 tm_mon;
 int8 tm_hour;
 int8 tm_wday;
 int8 tm_sec;
 int8 tm_min;
 int8 tm_isdst; // Not used by built in functions
 } time_t;
 but I could not specify using struct. How can I resolve this?
