USB CDC problem
geolover
USB CDC problem
PostPosted: Tue Mar 22, 2011 3:39 pm     Reply with quote
Hello! I had successfully implemented an USB CDC with 18F4550 to retrieve data from a PIC24FJ by using a SPI interface, however, between each operation, at least 100us delay must be added to ensure the data sent by PIC24FJ does not get corrupted....
I think the problem lies with the use of #use delay() because for PIC18F I'm using a 20MHz crystal to Operate at 48MHz, in PIC24FJ however I set #use delay() to 8MHz....
  #include <18F4550.h>
  //configure a 20MHz crystal to operate at 48MHz
  #fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
  //#fuses   USBDIV, PLL1, CPUDIV1, PROTECT, NOCPD, noBROWNOUT,HSPLL,NOWDT,nolvp, VREGEN
  #use delay(clock=48000000)
// If you are using a USB connection sense pin, define it here.  If you are
// not using connection sense, comment out this line.  Without connection
// sense you will not know if the device gets disconnected.
//       (connection sense should look like this:
//                             100k
//            VBUS-----+----/\/\/\/\/\----- (I/O PIN ON PIC)
//                     +----/\/\/\/\/\-----GND
//                             100k
//        (where VBUS is pin1 of the USB connector)
///only the 18F4550 development kit has this pin
// Includes all USB code and interrupts, as well as the CDC API
#include <usb_cdc.h>
#rom int 0xf00000={1,2,3,4}
   int i;
   int8 value0[1024], value1[1024],value2[1024];
   setup_spi(spi_slave | spi_ss_disabled);
//   setup_spi (SPI_MASTER | SPI_H_TO_L | SPI_CLK_DIV_4);
   usb_cdc_init();
   usb_init();
   while(!usb_cdc_connected()) {}
   do {
      usb_task();
      if (usb_enumerated()) {
//         printf(usb_cdc_putc, "\r\n\nData read from ADC:\r\n");              // Display contents of the first 64
      if (spi_data_is_in())
//    while(!spi_data_is_in());    // wait for SPI activity from master
       // Read byre from SPI interface
     for (i=0;i<1024;i++)
      value0[i] = spi_read();
      value1[i] = spi_read();
      value2[i] = spi_read();
//   for (i=0;i<256;i++)
//   printf(usb_cdc_putc, "%2x ", i);
     for (j=0;i<1024;j++)
      // Write byte to USB
       printf(usb_cdc_putc, "%X%X%X\r",value0[i],value1[i],value2[i]);
      }while (TRUE);
#FUSES NOCOE                    //Device will reset into operational mode
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#FUSES PR                       //Primary Oscillator
//#FUSES PR_PLL                   //Primary Oscillator with PLL
#FUSES CKSNOFSM                 //Clock Switching is enabled, fail Safe clock monitor is disabled
#FUSES NOOSCIO                  //OSC2 is clock output
#FUSES XT
#use delay(clock=8000000)
#use rs232(UART1,baud=9600,parity=N,bits=8)
