How to configure IOC on PIC16F917
steve_smith94
PostPosted: Mon Mar 21, 2011 5:22 am     Reply with quote
I'm a PIC newbie and have been given a circuit and asked to write the software.
I need to recognise a High (5v) on either RB6 and RB7, provided by a momentary push button switch. Then run code dependant upon which button is switch.
I have tried all the examples i can find on configuring the interrupts and can't seem to get it to work.
One obvious problem is that I'm unable to use pullups on port B as I need to trigger on a high.
Any pointers would be most welcome.
PostPosted: Mon Mar 21, 2011 6:03 am     Reply with quote
Without seeing the code you wrote it's very hard to tell you what's wrong !
Could be your hardware setup, could be software...
Wrong or missing pulldown resistors, power supply incorrect,defective switches, bad wiring, just to start...
Sounds like you want a low-to-high interrupt. you will need debouncing on the pushbuttons.
The example that CCS supplies will work,the help file has an FAQ section.
PostPosted: Mon Mar 21, 2011 1:18 pm     Reply with quote
But you control the source code. You can use positive logic or negative
logic. The C language is completely flexible with respect to that.
Here is the normal way to connect a push-button switch to a PIC:
           +5v
            > 4.7K
            <         ___ Push button switch
To          |        _|_|_
PIC -----------------o   o------
pin                            |
                              --- GND
However, sometimes on PIC hobby websites, you will see it wired the
opposite way. When you press the switch, it connects the +5v Vdd voltage
to the PIC pin. I suspect you are looking at one of those websites.
This thread has links to several push-button switch example programs:
http://www.ccsinfo.com/forum/viewtopic.php?t=42285
steve_smith94
PostPosted: Tue Mar 22, 2011 3:42 am     Reply with quote
Thanks guys.
\My code is below
#include <16F917.h>
#device adc=8
#FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES MCLR                     //Master Clear pin enabled
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#FUSES RESERVED                 //Used to set the reserved FUSE bits
#include "C:\Documents and Settings\Smiths\Desktop\test\test1.h"
  #include <float.h>
  #include <math.h>
  #include <stdio.h>
  #include <stdlib.h>
  #include <string.h>
  short int dbutton6, dbutton7;
#int_RB
void  RB_isr(void)
   int current;
   static int last=0;
   set_tris_b(0xF0);
   current=input_b();
   if ((!bit_test(last,6))&&(bit_test(current,6)))
      //b6 went High
      dbutton6=1;
   if ((!bit_test(last,7))&&(bit_test(current,7)))
      //b7 went High
      dbutton7=1;
delay_ms(10);
void clear_delta()
   dbutton6=0;
   dbutton7=0;
   setup_adc(ADC_CLOCK_DIV_2);
   setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_CLK_DIV_4);
   setup_lcd(LCD_DISABLED);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   enable_interrupts(INT_RB);
   clear_delta();
     output_bit(PIN_D0,0);
     output_bit(PIN_D1,0);
     output_bit(PIN_D2,0);
     output_bit(PIN_D3,1);
     output_bit(PIN_D4,0);
     output_bit(PIN_D5,0);
     output_bit(PIN_D6,0);
     output_bit(PIN_D7,1);
     delay_ms( 1000 ) ;
     if(dbutton6)
         output_bit(PIN_D0,1);
         output_bit(PIN_D1,1);
         output_bit(PIN_D3,0);
         output_bit(PIN_D4,1);
         output_bit(PIN_D5,1);
         output_bit(PIN_D7,0);
         //dbutton6=0;
         delay_ms( 1000 ) ;
     if(dbutton7)
         output_bit(PIN_D2,1);
         output_bit(PIN_D6,1);
         //dbutton7=0;
         delay_ms( 1000 ) ;
All that happens is two 7 seg displays output figures dependant upon which switch is depressed( RB6 or RB7). Unfortunatly the hardware switches +5v Sad
There are no pull down resistors on the inputs. However, scoping the pind RB6 and RB7 the levels look good. But I will try to place some pull downs on the lines and report back with my findings.
Cheers
steve_smith94
PostPosted: Tue Mar 22, 2011 3:45 am     Reply with quote
Just one further question; what size pull downs would you suggest? 4k7 as per pull ups?
steve_smith94
PostPosted: Wed Mar 23, 2011 9:20 am     Reply with quote
I have downloaded the real pic simulator to aid my getting to the bottom of this issue.
Using this configured for a PIC16F917, I can't get any of the examples I have seen to work.
Is there a ccs compiling issue for this PIC?
Does anyone have any ideas how I can get an int_rb interrupt to work with this PIC? I have now pulled down my 2 ports using a 10k res (still no joy). But seeing the simulator also doesn't work I guess that it must be a software issue.
Please help Crying or Very sad
