Reset on IO pin
Pekub
Reset on IO pin
PostPosted: Fri Mar 18, 2011 7:32 am     Reply with quote
I have a very simple program for PIC16F1824.
Compiler V 4.119
If I set low level on the RA2 pin, the processor resets.
When I delete a row with the settings pull up, it's all okay.
Please, what is wrong ?
#include <16F1824.h>
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES NOMCLR
#FUSES NOWDT                      //Watch Dog Timer
#FUSES NOPUT                      //Power Up Timer
#use delay(clock=16000000)
#zero_ram
   disable_interrupts(GLOBAL);
   setup_oscillator(OSC_16MHZ|OSC_INTRC|OSC_PLL_OFF,0);
   setup_adc_ports(ADC_OFF);
   // whith this code, procesor reset when RA2 -> 0
   port_a_pullups(TRUE);
   port_a_pullups(0x04);         // pullup odpor na PIN_A2
   // whith this code, it's O.K.
   // port_a_pullups(TRUE);
   // port_a_pullups(0x04);         // pullup odpor na PIN_A2
PostPosted: Fri Mar 18, 2011 11:49 am     Reply with quote
Remove the #zero_ram line. It may be over-writing something.
Also, simplify the program. Remove the setup_oscillator() line.
Change the #use delay() to 4MHz.
Pekub
PostPosted: Fri Mar 25, 2011 3:50 am     Reply with quote
Thank you for your ideas. I tried them.
I found that this problem is not with the pull up resistor.
The problem is not software but hardware.
Input A2/INT in this chip is very sensitive to noise and interference, what causes a processor reset. I decided to use this pin as an output.
