PIC based DNS server
Will Reeve
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
PostPosted: Fri Mar 11, 2011 4:53 am     Reply with quote
Can the stack run a DNS server? I just need one manual entry to resolve say www.mypic.com into the IP address of the 'PIC'.
If I type the ip address into the browser it works fine, but it would be very nice to resolve a name to it.
There are no outside world connections to worry about, the network is restricted to one device at a time using the DHCP server.
gpsmikey
PostPosted: Fri Mar 11, 2011 7:04 pm     Reply with quote
What are you trying to connect to the pic with ? While DNS would be nice, you can use a fixed IP for the PIC and put it's "name" (mypic.com) in the host file on your machine and it will resolve that way. Would that solve the problem ? (on Linux machines, it should be in /etc/hosts and on Windows I think it is in C:\WINDOWS\system32\drivers\etc\hosts - at least that is where it is in XP)
mikey
mikey
dbotkin
PostPosted: Sat Mar 12, 2011 8:25 am     Reply with quote
IF you were able to run a DNS server on the PIC, you'd still need to point your PC to that PIC as your DNS server. Far easier and cleaner to just use a hosts file entry on your PC, or fix your local DNS if you have control over it.
